I have just tried to submit a filter I have made with FF 4.0 that is based on the stripes theme, and I have used my own original account and surprisingly I have been able to submit the filter succesfully without any problem.
So it seems that the problem is NOT with my account, because I have been able to use the FF 4.0 with my account and the same submit server, so my account is working right IF you use FF 4.0 unless there is a different server for FF 3.0 filters and another for FF 4.0
So then, how is possible that I can submit without any problem using FF 4.0 and my account, and I can´t submit any filter with FF 3.0 with my account, but I can submit with FF 3.0 with a new account.
FF 4.0 + my account : Sucess
FF 3.0 + my account : Not possible with any filter
FF 3.0 + New account : Sucess
SpaceRay, please let me know the exact error message you get.
SpaceRay stress testing FilterForge library.
I have just now tried to submit again the filters
1 - Color Squares update filter to the previous one have finally been done sucessfully now, something that it did not work this morning.
2 - Grunge Heart Frame - Can´t submit, after finished the 9 rendering I get now a different error than before
Yesterday I got
"Submission failed. Connection error. Reason:'submit_filter()failed.' Please try again later
Today I got the one seen on the screenshot below
"Submission failed. Connection error. Reason:'Logical Protocol ocurred' 'submit_filter()failed.' Please try again later."
If you want to see the filter to see why is giving the error shown above, I upload it here for you
Will try to submit the other filter and see what happens
Grunge Heart Frame.ffxml
Don't know if this is all your problems but you have a connection error to work out in the filter.....
You should fix these before submitting otherwise YOU WILL GET SUBMISSION ERRORS...
I have been able to submit two new filters now using filter using FF 3.0 and my own account
should I try to submit the stripes filters?
Well I can´t fix something that is NOT broken in my filter WHEN USING FF 3.0, maybe it becomes broken when using FF 4.0
Here is the screenshot of what I have from FF 3.0 and you can see that there is no error in any link
It is broken, though your FF 3.0 doesn't display this as a problem — but the server-side 4.0 rejects the filter.
Well, the situation is clear. While we're fixing it you can lower the Max value of the IntSlider (as shown on the CFandM's screenshot) and submit the filter.
YES! it did work and have submitted the filter successfully using FF 3.0 when lowering the max value, and using my account, thanks.
As I have now FF 4.0 I have tried again to submit the stripes filter, I am happy to say that IT WORKED, I have been able to finally submit them sucessfully using my own account without any problem!! So it seems that the problem was with FF 3.0 as with FF 4.0 works right.
Thanks for all your help
23 unregistered users.
