johnE
JohnE
I am running a fast Mac laptop and I have very slow rendering times. I installed FF on my Windows (via parellels) and it too takes forever to render to file.
I am rendering a 6700 x 8300 photo. I am using the Old Photo filter. I am guessing it based on the progress indicator it will takes 1-2 hours (I abandon after 20 minutes or so) on the Windows version and it seems about the same on the Mac OS version.
I really like FF and I want to purchase it but the render times are not workable and from other threads I have read are not typical although other have certainly complained about the same problem.
Help please....
That's actually pretty normal for the resolution you're rendering at.
A lot of user submitted filters aren't entirely optimal, and also filters made with FilterForge aren't "hard-coded", as in specifically programmed by code, they're programmed by node. The sort of freedom of using nodes we get in the program comes at an expense of render times unfortunately. (I'm kinda talking this based on what I've collected over the years). I hope you understand.
I typically work the problem around by exporting layers of the filter, though this kinda doesn't work entirely with all filters. If I'm also working with a surface based filter, I typically export render maps and never deal with lighting. You can also try disabling anti-alias, given your resolution, you're likely able to get away with it. But in the end you kinda do have to deal with the render times.
As a guy using filterforge for all these years, I can pretty much say as a community we're trying to make optimal filters to the best of our knowledge but render times would probably remain an issue.
[Edited for clarification]
I wonder why are you using the Windows version having already a fast Mac computer?
Why are you not using the Mac version instead?
Actually SpaceRay's caught it right, I probably numbed out and didn't read the whole thing. Why are you using it on Parallels? Parallels will take some level of CPU power given you're using both Mac and Windows at the same time. It'd probably go faster just running it solo on a Mac without emulation.
johnE
JohnE
I read about slow render times in some posts. The common consensus (fr om 2012) at the time render times were slow because of the MAC OS. So I just experimented in Windows and the render times are about the same.
Some of the filters are very cool but if you are experimenting and you have to wait hours to see if you like an effect and if you are combining with other FF effects in Photoshop you literally could spend 20+ hours rendering a few variations out.
I guess I should experiment with very small jpgs and that might help speed the proof-of-concept stage up.
I am used to software programs like NIK tools wh ere 5 seconds to render out a large file seems pretty normal.
Ahoy. That shouldn't be the case at all, if anything, I would have observed that and reported it since I do use both systems with identical specs. You're also emulating Windows on a Mac which affects performance significantly. When you emulate a system, you're allocating resources to run an emulated environment while running MacOSX. It requires a level of CPU / GPU distribution for it to work hence you're only getting a percentage of performance running FilterForge on an emulated system anyway.
FilterForge on either system works the same way. I don't see a ridiculous difference in render times so I wouldn't blame the system.
Also do note some of the forum posts bluff up the speed issue and several posts are just incredibly unfair / biased / misinformed of the nature of FilterForge and how it behaves. To be fair those people, I sometimes do think FilterForge is a bit slow, but I just hardly think it's fair to make an argument without understanding the underlying concepts. smile;)
SPEED TEST MADE with 8400x9000 pixels
I have made the test in my own computer for you with the defailt first preset and it takes for a 8400x9000 pixels 43 minutes to finish rendering
I have Windows 8 with Intel Quad Core 3.4Ghz i2600K and configured RAM to 60%
johnE
Fr om the speed tests I have already done before, this does not work, because on smaller jpgs the difference may be very little, and will not help to really test the speed difference. If you want to use smaller jpgs I can suggest to begin with at least 2000 x 2000 pixels or higher.
The time of the rendering increases much with higher resolutions
johnE
Well, you CAN´T compare the rendering time of Filter Forge (FF) with any other plugin like Nik, OnOne or Topaz Labs, because they are NOT generating the image as it happens inside FF, they are only applying an effect to an image or photo that is already created AND as Skybase have said very well, the filters that you use in FF are not hardcoded and very well optimized as they are in these other tools.
The only way that FF could be faster is to have a monster faster CPU or that the FF team could make a new render engine with OpenCL hardware acceleration or find another way to improve the render speed
ABOUT RENDER SPEED OF FILTER FORGE
As Skybase have said right, the speed issue, is NOT for ALL the filters, and it will depend very much on the filters you choose, there are available filters very fast, and some very slow, and a whole range of different speeds in the middle.
I can´t tell how many filters are fast or slow, you have to test them, some filters only takes a few seconds, others a few minutes and others could take take hours.
And of course ALL depends very much at how big is the resolution
PayPaul
PayPaul
There are three filters I have that render at very slow speeds. Cut It Out in 3d and Dragon Dreams are two of the three but are still faster then the next one. The biggest resource hog of all is Spherical Displacement. From this thread I understand it is the number or complexity of nodes that effect the rendering speed. The above filter can use up to 99% of the CPU and takes 2 hours to render a 4288 X 2488 jpeg. I have an Intel i7n 5500U Broadwell processor on a 12GB Ram laptop. I also understand that it is mostly the CPU that is used during the rendering. FF4 uses about 2 to 3gb of Ram at its highest point. What can I do to reduce rendering times?
Don't step on a dead dogma. It'll turn up again and bite you!
One method is to go into the filter itself and render out specific sections contributing to the filter's look. This is slightly advanced as a technique but just like how you'd compile your stuff in layers, many filters have specific "layers" to them in which results in the overall image. In some cases you can manually achieve the same effect in Photoshop alone.
In some cases you can simply render out the diffuse map and manually add in the lighting effects later.
I also suggest manually going in and optimizing the filter itself. Which is tricky. There's a tendency for novice filter authors to leave a bunch of slow-moving, unoptimized loads of stuff in filters. These things can sometimes lead to extremely slow renders.
PayPaul
PayPaul
Is there a tutorial on how to do that?
How does one manually optimize a filter? That Spherical Displacement filter has a lot of nodes. A pretty complicated filter.
I should have mentioned that these are all relatively advanced techniques.
Nop, and it also depends on a filter. There are some filters where you can't do some things. For example, Spherical Displacement is one of those effects where you can't really separate out specific layers to recombine them later in Photoshop. It takes a bit of understanding of FilterForge and Photoshop skills to determine if you can recombine elements of a filter later in Photoshop manually.
With the diffuse map, you basically just get the "color" pass. Generally it's intended to be for 3D texture work. The idea being the diffuse pass gives you no lighting what-so-ever hence less calculation and therefore less render time. I generally hand-paint lighting so this method works for me... if I ever want something fast.
Probably not for Spherical Displacement after all, it's created by a very advanced user. This technique is intended more for filters that have sloppy construction or unoptimized junk. The method does require some advanced FilterForge understanding.
ONE MORE THING since those methods I mentioned are PRETTY advanced I thought of another one that I forgot... I should have said it first.
Try disabling anti-alias. By default it's set to 5 samples. It usually significantly reduces render time at the cost of jaggy edges, although if the images are large enough, you can surely get away without it.
PayPaul
PayPaul
That did work when I went to Filter> Anti-aliasing and disabled it. I saw a significant reduction in rendering times for an 1800 x 1800 image using spherical displacement. Thank you very much!!
33,857 Registered Users
+44 new in year!
44 unregistered users.
