In the Submit wizard help page is not explained, so I wonder how the submit works as lately it seems to be happening sometimes to some users that you can´t submit a filter as when you are ready to submit it tells you the following message
"Submission failed. Connection error. Reason:'submit_filter()failed.' Please try again later."
Why in point 16 in the list below I get the error message shown here above and can´t then finish the submit process?
How is possible that it has been able to connect with the submit wizard twice in points 6 and 9 and it worked right but then when going to submit it, it does not work?
What is different than connecting to get the needed data information for the submit wizard and then after sending the filter to the submit queue?
I have been trying to submit two different filter updates since saturday 28 December, 6 days ago, as today is 2 January, and I have tried many times and it does not work
Possible reasons for this error message:
1 - Internet Connection problems (NO internet at all)
2 - Internet working but having problems to connect to the server
3 - Firewall in security software could be blocking the access of submit wizard to server
4 - Submitting Server is down or non working
WHAT HAPPENS WHEN TRYING TO SUBMIT A FILTER?
1 - I open Filter Forge 3.0.15 (latest update)
2 - Choose the filter to be submitted
3 - Go to menu Filter --> Submit to Library...
4 - Click next and accept license agreement
5 - Log in with your account
6 - Submit wizard connects to the submit wizard server
7 - Asks if it is a new filter or an update
8 - If it is an update it will ask to choose which filter to be updated
9 - Connects again to the submit server to show the categories structure
10 - Choose the category you want for that filter
11 - Review the text written in the About and update tab and can edit it if needed
12 - Renders the 9 thumbnails needed for the filter
13 - Rendering complete, "To continue the submit process, click next"
14 - Ready to submit, "To complete the submit process, click next"
15 - Connects to the submit server to "Add the filter to the submit queue
16 - If submitted succesfully it ends here, but if not, you can get an error message, for example:
WHY THIS HAPPENS? HOW IS THIS POSSIBLE?
If the submit wizard is broken, down or non working in the point 6 AND point 9 it would not work, and you would not be able to connect with it to continue the submit wizard, so if it works and you can connect to the submit server then none of the 4 points of the reasons I have put above are not true:
1 - as you have internet
2 - you can connect to the submit server
3 - the firewall is letting Filter Forge submit wizard access to the submit server
4 - submit server is working as you have been able to connect to it.
So here comes the mistery and reason to make this thread and as already asked at beginning is why is this happening and how is possible that it can connect right for points 6 and 9 and can´t connect for the final sending of the filter to the server?
For some FF users it seems that this has been solved by itself through time without doing nothing to fix it.
In the already 6 days that I have tried many times, it always happens the same and it does not get fixed by itself
Sharandra
Filter Forge Addict
Maybe the server is down? I guess the FF team took a well deserved break over the holidays, so just be patient.
Could this be something related only to the software and not with the submit server?
I mean that perhaps it could be working right the submit server and it could be working right with FF 4.0 but maybe NOT working with FF 3.0
I can´t test FF 4.0 as my trial has ended.
Sharandra
If the server is down I wonder how is possible that I CAN connect to the submit server twice to get the data information for needed for the submit wizard process AND then at the end you can´t submit the rendered filter?
Are there TWO different submit servers? I mean one for the data information of the submit wizard and another different for storing the final filter? so the first one is working right and the second is down?
Sharandra
Well I am NOT in a hurry and is NOT urgent at all to be able to submit the filter update and I can surely wait and there is no problem, BUT is curious, weird and a mistery that you can do all the submit wizard process and at the very end it gets broken
Of course that the FF team needs a well deserved break on the holidays after releasing FF 4.0 and also so the New Year, and I am not requesting that they come back to solve this, as is not urgent.
32 unregistered users.
