aba
Batchman
FF3 had a FFXCmdRenderer-x86-SSE2.exe and a FFXCmdRenderer-x86.exe. FF 4.0 only has a FFXCmdRenderer-x86.exe. Will there be a SSE2 verson for FF 4.0?
Quote from help:
On older computers with CPUs that don't support the SSE2 instruction set (Intel CPUs prior to Pentium 4 and AMD CPUs prior to Athlon 64), use FFXCmdRenderer-x86.exe instead of FFXCmdRenderer-x86-SSE2.exe.
So I expect some performance gain with the SSE2 version. I also have some troubles with bigger pictures (4000x4000) that worked with FF3, maybe that could be solved with a SSE2 version??
It's just the opposite: the non-SSE2 version was dropped from Filter Forge 4, and the SSE2 build was renamed to Filter Forge x86.exe and FFXCmdRenderer-x86.exe.
Thanks for pointing to the help, we need to change it accordingly.
32 unregistered users.
