Jeffrey Davis
10 out of 10 tries, Filter Forge x86-SSE2 1.005.3382.26466, Save Image As,
Focus returns to Filter Forge window upon saving image.
Steps:
1. Select a Filter that takes awhile to render (such as Vladmir's Creepy under Organic).
2. Enable anti-aliasing at any setting (to lengthen the render).
3. While the Filter is rendering, select Save Image As.
4. Save the image as a JPEG (test case; any image type reproduces the bug).
5. Select any Quality and select OK.
6. Navigate to another running program.
7. Notice when the render finishes, the focus returns to the Filter Forge program.
Note: User may inadvertently introduce unintentional input into Filter Forge. Suggest playing a sound or using an unobtrusive visual cue instead.
Now that's what I call a bug report. The programmers are working on this.
Bella
Filter Forge, Inc.
Already fixed! smile;) smile:D The fix will be included into the next update. Jeffrey, thanks for reporting this!
