Rick Quisenberry
I just installed Filter Forge 4.0. While it seems to run okay as a stand-alone program, It consistently hangs when I run it as a filter from Photoshop CS6. The FF window begins to open, but is completely blank and is completely non-responsive. When I cancel the FF task, the following message is display (by Photoshop, I presume):
<class XFW::OSCallError> ::WriteFile(block4, child pipe 00002AB4, master pipe 06907400) failed with error code 0x00000E8: The pipe is being closed.
I had similar problems running FF 3.0 with Photoshop CS6, and could only use it in standalone mode.
Currently, I’m running windows 7 – 32bit.
Any help would be appreciated.
Rick Quisenberry
25 unregistered users.
