MKBreuer
MKBreuer
Filters: 47
Hy! I have a Submission Error...
Please check it out above if you have time...
mw_Mystic Magic.ffxml
Just simple, but not simpler. (A.E)
Djekki
Filter Forge, Inc.
Filters: 2
Wat version of Filter Forge do you use?
Regards,
Jane
MKBreuer
MKBreuer
Filters: 47
Filter Forge 3
Djekki
Filter Forge, Inc.
Filters: 2
You need to do the following to submit this filter normally:
1. Find all Polygon components in your filter.
2. Then find all the IntSlider Controls connected to the Sides control input there.
3. Change the Max Value to 98 everywhere (in every IntSlider control connected to the Sides input of the Polygon component) and you'll be able to submit your filter without an error.
The thing is the bug (I'd call it like this) is somehow fixed in the 4.0 version: there you'd have a warning message to change the interval of the Value (Max interval is 93).
Regards,
Jane
MKBreuer
MKBreuer
Filters: 47
It worked! THX! smile:)
Djekki
Filter Forge, Inc.
Filters: 2
marwyn, our developers've already fixed this bug: now you can submit the initial version of the filter if you want. This type of bug should not occur again.
Regards,
Jane
Submission problem
Is there still a problem with Int Slider > 20 on submission with FF 4.004? I can't submit a filter that has one. (Can't attach it here either as it is over 512kB.)
Djekki
Filter Forge, Inc.
Filters: 2
ThreeDee, where is the IntSlider connected (component and input)?
And please, send a screenshot of the filter or a link to download your filter (from the Dropbox or Google Drive or smth).
Regards,
Jane
Djekki
ThreeDee have already uploaded the filter in this thread here
Look for the post where it puts Arial TD Font and there are two filters.
I think that it would be better to upload it to the library also separate in lower and upper case and not as all together in one filter, but this is just my personal and own opinion
ThreeDee, does your filter have 52 presets? This is over our maximum limit of 20 presets. The issue with IntSlider > 20 must have been fixed in 4.002.
Here's a screenshot of the filter. I have the IntSlider connected to two Map Scripts with 27 as the max value.
For the submitted version I removed extra presets, so that there were 20 of them. Submission fails at the last step.
I sent Djekki a link to the file on Google Drive.
Your filter is almost 700 KB, and at the moment we have a 512 KB limit on the filter size smile:)
Will now check if this limit is something easy to change.
We've increased the ffxml size limit to 1024 KB. You should be able to submit it now, and please don't create filters larger than 1 MB smile:)
Ok, great. Worked this time. So the Arial font snippet is the largest filter ever submitted, eh? With grouping in FF4, you can expect to raise that limit even higher... smile:D
MKBreuer
MKBreuer
Filters: 47
Info for > !_Submission Error_!
If you have done a submit and it failed, don´t close it:
> sometimes it is a missing Cookie for Filter Forge.
1. go to any Filter on Filter Forge
2. click on the Button > Open this Filter in Filter Forge
3. install the missing Cookie from the new Side (click on the Link)
4. than Repeat your Submit
12 unregistered users.
