i've already sent in two bug reports on this one, but thought i'd post this in case someone had a quick fix (i really want to try out the new multi-blending as soon as possible), so, i'm posting it here also.
the first bug was reported from trying to download the new version. i simply went to 'download filters' and it gave me the normal message that i needed a new version and did i want to update now. i said yes and the download started and ran just fine. when the download was done, whatever comes next crashed FF back to the desktop and i got the error message on the desktop.
so, i started FF again, hoping that maybe this was a non-critical error and that it might finish the process of installing the new version. i again went to download filters but since i already had the download from the previous attempt, FF just crashed back to desktop again and i got the same message again.
like i say, i have already filled out the generated bug report forms. and, FF does still work; i just cant download any more filters or install the new version. my version still shows ver 1.004.
one additional note here, that i dont know if it would affect things or not, is that i recently got an email from bella over another bug fix. i had to copy the 1.004 .8bf file over to my plugins folder. i also copied the config file over as well. that would be the ver 1.004 .8bf into my plugins that apparently had an older version in it and was causing a problem when i used FF as a plugin from paint shop pro. i doubt this is affecting the new download, but i mention it anyways just in case.
so, any quick fixes here would be great!
ok, i got 1.005 installed. apparently the automated thing going to 'download more filters' is what was doing it. when i picked 'updates' from the tools menu, i actually got the installed and it ran just fine. i now have version 1.005!! and i LOVE the new multi-blend!!!
Craig, you are right.
In order to update to version 1.005 correctly, please use Tools > Updates... command in the menu.
Alternatively, you can download a new setup file.
Other ways to update the program may lead to a crash. This has been fixed in the latest version, so the update to the following version will hopefully work OK.
thanks, gmm.
Whitedove
Miss Congeniality
Hi Guys!
Same thing happened to me, but I only crashed once, then I went hunting for a solution and found it. Everything is A-OK now!
After Thanksgiving I'm going to try making some more filters, haven't had time to blink!
TTFN
Donna
TnMtnGirl
TnMtnGirl
I have/had FF version 1.009, I did the update,{fr om the link given in this forum} to version 1.021, and now it gives me the choice of buying again, or using the updated version for 30 days. WHY??? I was reading in this forum wh ere as long as the up is in that version, it is supposed to be free. If I would update to a NEWER version, say like the 2.0-3.0 beta...I would have to buy it. Can someone help me??
Probably the support team can.
31 unregistered users.
