Jessie
Hi,
I having this error when processing the photo using Filter Forge. May I know why this error will occurs and how to solve this problem?
Many thanks.
Regards,
Jessie
Jessie
Jessie, what OS do you use? Does the issue occur in the plugin or standalone mode? If you use Filter Forge as a plugin, under what host application?
Jessie
Hi,
I am using Windows 7, this issue occur in standalone mode using cmd(command prompt).
Thanks.
Jessie
Jessie
What do you mean by "cmd(command prompt)"?
Command Prompt on Windows is the same thing as Terminal on Mac, i.e. he is using the command line renderer.
There's a command line renderer? I guess I never payed attention to that. smile:D
Jessie
Yes, I am using the Command-Line Renderer under Windows.
Jessie
Please locate the "Filter Forge x86-SSE2.log" file in your temp folder and send it to the support team or post it here.
Jessie
I search for the log file in "C:\Users\new\AppData\Local\Temp", but there is no "Filter Forge x86-SSE2.log" file. Furthermore, this error does not always occurs.
Jessie
Unfortunately we're unable to reproduce this. If you could describe the steps to reliably reproduce the issue, let us know.
