| Eflouret |
Hello,
I've just published in my blog an guide about programming Photoshop plugins. In this article, Filter Forge is mentioned as a developing tool. This is the link: http://www.photoshoproadmap.com/Photo...p-plugins/ I'm trying to keep this guide as accurate as I can. Any suggestions or corrections will be appreciated. Thanks! Enrique |
| Posted: October 23, 2006 9:28 pm | ||||||||||||||
Administrator |
Enrique -- thanks for the great article! I'll comment on some of the points:
Absolutely, positively true!
I'd add that for a plugin programmer Filter Forge can be an excellent prototyping tool -- it allows to focus on the algorithm and eliminates the need to code all the necessities first (rendering code etc etc). Plus, it already has many well-known image processing algorithms implemented as components.
One of the reasons why Filter Forge doesn't create standlone 8bf filters is that it uses HDRI images licensed from Sachform (http://www.sachform.de) for lighting, and our agreement with them does not permit embedding these HDRIs into stand-alone filters. Here's the link to an earlier discussion on this topic: http://www.retouchpro.com/forums/soft...rge-2.html
Yes, the number of bugs we found during the public beta was surprisingly low -- especially for a project that has over 210 000 lines of code.
Hehe -- fully agree with this
Regarding the speed -- yes, Filter Forge can be slow on some filters. On the other side, it scales very well with multi-core processors -- we've seen speedups over 96% per core. Dual-cores are already mainstream, quad cores are coming next year, and Intel promises 16 (or was that 32?) cores by 2010, so you can be certain that Filter Forge will get faster every time you upgrade your PC Thank you again for the excellent article! |
| Posted: October 24, 2006 10:30 am | ||||||||||||||
Administrator |
We discussed this recently: http://www.filterforge.com/forum/read...=9&TID=951 |
| Posted: October 24, 2006 10:34 am | ||||||||||||||
Administrator |
I second that -- Filter Forge uses Inno Setup as well. |
| Posted: October 24, 2006 10:36 am | ||||||||||||||
| Eflouret |
Thanks Vladimir for your input!
I've just updated the article with some of your interesting comments. Enrique |
| Posted: October 30, 2006 11:46 am | ||||||||||||||
