gorilla104
Multicolor Dots:
Very nice filter, but I cannot make circles only.
Some help pls.
Thanks again
I suposse you are refering to this filter by Ghislaine
http://filterforge.com/filters/10039.html
What happens with the filter that you can´t use it?
If you need help, it would be much better that you explain what happens in more detail.
As Spaceray said, I need more details, because my filter works find on my pc.
gorilla104
Thanks a lot to both Ghislaine and SpaceRay.Ideed.
First I' working on iMac 27' i5 12GB Ram. Photoshop CS5 or standalone.
Working with masks on a layer 80cm H and 50 cm L 254 dpi.
In Test 1 (T1 file) only 1000 x 1000 px and it works perfect!!!!!
In Test 2 (T2 file) just to make an example.... 5000 x 6000 px and it doesnt make circles....
I spent an hour tuching all settings but I cannot work at hi res. (in my case 254 dpi)
Thanks a lot
bye from Italy
gorilla104
I make a mitake,sorry, not woking with masks but with selections
bye
And the error comes only hi res in Photoshop and Standalone mode
bye
Glad that you have resolved the error.
The filter was created for squared image. By using it with an hi-res more highter than larger, this gives something as the example you posted.
gorilla104
I understand.
Thanks a lot, now I know how to use it.
Nice filter!!!!
bye
87 unregistered users.
