Beth Rosengard
I'm on a Mac OS X 10.5.8. I've successfully installed FF3.
Assuming that all the FF2 filters will work in FF3, how do I transfer them from the old version to the new version?
TIA, Beth
just do a search in the forums. this has been stated several times here.
The simple answer is to copy this whole folder to the same location on the other machine.
FOR MAC OS
From FilterForge 2: ~/Library/Application Support/Filter Forge 2/system
Copy to the same folder to
FilterForge 3: ~/Library/Application Support/Filter Forge 3/system
Please, see this threads here for more information
Moving Filters From 1 Computer to Another
Where are the downloaded Filter Forge filters located physically?
Be aware that the MY FILTERS folders and MY PRESETS must be copied too if you have made your own presets or your filters.
You can copy this folder to the same location on the other machine.
FOR MAC OS
FilterForge 2: ~/Library/Application Support/Filter Forge 2/My Filters
copy to
FilterForge 3: ~/Library/Application Support/Filter Forge 3/My Filters
FilterForge 2: ~/Library/Application Support/Filter Forge 2/My Presets
copy to
FilterForge 3: ~/Library/Application Support/Filter Forge 3/My Presets
22 unregistered users.
