Hello smile:)
1. Usually and normally, a forum must contain a search bar where typing keywords for easy research. Here, there is no search bar. It would be fine to get one.
2. At right, it just shows the last 7 posts or replies. It would be fine to get able to see more or a possibility to see all posts since our last visit.
We loose a lot of time in search without these 2 points. Is it possible to insert these points in this forum ? smile:)
I'm sorry. I just see that there is a search bar.
Well, I'm trying to find where do I insert the alpha map when creating filter. Because I'm created a filter and want to get the alpha on the result. The filter that I'm trying to create is a TreeMetallizer. But the result do not show the alpha.
there are two components for alpha layers. one is the 'get alpha' and the other is 'set alpha'. they are both located in the 'channels' section of the components; just scroll down to see them.
how you use them shld be explained in the helps... i think.
there's been some discussion over whether these are constructed the right way, so search the forums also.
Sorry, what do you mean there is no search bar feature in the FF forum ?
Is this what you are looking for ?
http://www.filterforge.com/forum/search.php?FORUM_ID=5
You can find this here on the top
Active Topics_____Search___Subscriptions_____Mark All Posts as Read
25 unregistered users.
