Please, I want to ask you if you can be so kind and help to render two Filter Forge filters in YOUR COMPUTER and take the render speed time that it takes to finish
TEST 1 - Render a 2000x2000 texture using Crysta filter by Vladimir Golovin
TEST 2 - Render a 2000x2000 texture using Creepy filter by Vladimir Golovin
For this to be done easily, you just select the Crysta or Creepy filter and then choose NEW IMAGE and then on the size configuration put 2000 x 2000
If you then open the next filter it will already be configured to the same size.
I would be very grateful if you can make the renders and take the time and put the cpu processor you have and ram, and if using 7200, 5400 hard drive or SSD.
Not needed to count the seconds
Thanks very much for your help
FILTER FORGE CONFIGURATION
Please, use the default configuration on both FF as I have put the same configuration, and is the default configuration, I mean:
Use ALL available CPU/Cores
Use Direct X style
Using output dithering
Optimizing Blur Calculations
Temporary folder in C: with 56 GB free
Anti Alias OFF
Not using double precision
Gamma correction enabled
FILTER FORGE VERSIONS USED
FIlter Forge 2 (FF2) is latest 2.011 64 bit
Filter Forge 3 (FF3) is latest 3.03 32 bit
Using both in Standalone version (not using photoshop)
EXAMPLE OF WHAT I HAVE DONE TO MAKE THE TWO TESTS
NUMBER 1(N1) Old Computer
AMD X4 645
8 GB Value ram
5400 rmp Hard drive SATA 2.0 3GB/s
Nvidia Geforce 9600 GT with latest drivers
Windows 7 Home premium 64 bit
NUMBER 2(N2) New Computer
Intel i7 2600K
16 GB 14900 DDR3 Special RAM
SSD SATA 3.0 6GB/s
RENDER SPEED RESULTS
N1 - FF2 - 21 MINUTES
N2 - FF2 - 15 MINUTES
N2 - FF3 - 24 MINUTES
N1 - FF2 - 11 MINUTES
N2 - FF2 - 8 MINUTES
N2 - FF3 - 12 MINUTES
30 unregistered users.
