suzzie
Have 2.0 Pro on XP.
I have a textured skin base image for a 3d character that is very shallow and does not have a lot of (height and depth) texture to it. Its a flat 50% gray texture in jpeg format.
I would like to take this 50% gray skin texture and where the image is a bit darker than 128...then the apparent final depth of the texture goes down...and where the texture is lighter than 128 I would like to grow and deepen the texture height...so I can make the texture pattern as hairy as I want.
Is that something that may be possible with Filter Forge.
I do not have a 3d program I can do this with unfortunately ...and I wouldnt know how to do it to begin with.
Im going to use this heightened texture on another project.
Thanks for your help
Suzzie
saurabhgayali
Saurabh Gayali
Filters: 84
i think filters can be designed to work on it.
u need to explain a bit more here with ur image shared.
unfortunately all my trials expired. so u have do depend on other developers of filter forge community
saurabh.gayali@gmail.com
TBH-1138
Filters: 53
Is this what you want?
Contrasterizer.ffxml
17 unregistered users.
