anna22
Hi guys
i bought the pro account so could render larger jpg size images. If its under 10-12" it takes aprox 2-3 hours. 20" it takes overnight to render. 40" and it never completes the task (all at 300 dpi). Is this normal? Am i doing something wrong?
any feedback would be greatly appreciated smile:)
Ps' My pc has 2 GB
tigerAspect
Filters: 9
For 10" at 300 dpi, you're rendering 9,000,000 pixels, or 1250 pixels per second if that takes 2 hours.
For 20" at 300 dpi, you're rendering 36,000,000 pixels, or 8 hours at the same rate.
40" would take 32 hours, it's an exponential scale, not a linear one.
I can't say why a 40 inch square rendering never finishes, but maybe you're just not giving it enough time. If you want to increase the rendering speed you need a faster processor, not more memory.
anna22
Wow, thanks so much tigerAspect for taking the time to answer my question. i have never been good with numbers and your breakdown was extremely helpful. Guess next try will give it the full 32 hours to render, kinda gave up after the first 24. Have a great weekend smile:)
Wow.. what filter is that?
Some filters can be optimized dramatically (not all though, the look in some filters has its price..).
Here is the list of top performance killer elements:
1. Ambient Occlusion
2. Bitmap based components (blur, motion blur, high pass, sharpen, minimum /maximum, median, percentile)*
3. Bomber
4. Refraction*
5. Derivative*
* performance is related to their position in the overall filter tree..
But often there is no simple replacement, and you have to analyze the construction carefully..
Sometimes you can simply bypass the bitmap based ones and see if the change in final look is acceptable (the simplest way to try that out is to set their radius to zero, then they internally bypass).
anna22
Thanks so much Sphinx. It was the " Sketchy Painting" filter, one of my top faves. i am pretty new at this and im gonna have to do some homework. Have to admit most of what you wrote is over my head at the moment. Guess a good place to start would be to find out what a " bitmap" is. Thanks for taking the time, i really appreciate it. Have a nice day smile:)
I think I posted an optimized version of emme's sketchy painting once, but there is something wrong with the forum currently (you can't see the comments for the filter)..
37 unregistered users.
