you can now change the order of the controls in the GUI. you do this in the editor, not in the GUI. i forget the actual menu item where it's found, but it's in there! very cool!
craig
In the editor it can be found under Filter/Order of Controls... With the dots repesenting that it has a dialog that pops up. I think. smile:)
Exactly.
xirja
Idididoll Forcabbage
Any chance that in V3 the 'Custom' 'Order of Controls' will not be reset every time there is new connection / component added?
Totte
Übernerd
Filters: 107
+1
The custom order of controls is not reset when you just add a new component or control to the existing component tree.
It does get reset when you disconnect a subtree from the Result component — but this is a feature rather than a bug (no controls in the Result tree = default order of controls). You can press Ctrl+Z to undo the disconnection and get your OoC back.
Our recommendation is to set the custom OoC at the final stage after the filter is complete.
Totte
Übernerd
Filters: 107
Updating filters is mostly about adding new features, which leads to adding new controls, which often is adding a switch halfway to handle a selection of different image data flow steams, which means breaking the flow to insert the switch, which leads to a totally wacky control order.
Guru filter makers can open the ffxml file in a text editor, copy the customized <ControlsOrder> section and then paste it into an updated filter smile:)
Totte
Übernerd
Filters: 107
smile;-) Never thought of that (I have modified a V2 filter to work in V1 by modding the XML though). Good point.
But, then it would be easy to have a "Restore old controlorder" feature, you just have to snap that when a filter goes to edit, and the replace it back again when it goes out of edit, adding any new controls below.
xirja
Thanks Totte, GMM, I'm glad this wasn't my misunderstanding. Editing the ffxml, right, a good intermediate way.
BTW, kudos Totte for FFBatchMaster 2. Massive!:
20 unregistered users.
