RAGEZONEGEAR
RAGEZONE
When applying a filter effect to a png. file (i.e., a photo with a transparent background). The filter effect "fills in" the transparent area of the photo with the filter effect. How do I just apply the filter effect to only the area of the photo I want??
Render a selection map then load that along with it smile:)
IONclad
most filters use tiles or processes that eliminate the alpha. It should be possible to build a filter that would keep it.
ragezonegear,
think of the alpha areas as zeros and the effect you are applying as ones or, think of the alpha as a nothing and the effect as a something. nothing plus something is something. if you add zero to one you get one. the only way to keep from applying the ones to the zeros is to mask the zeros or make selections of the ones or zeros. FF doesnt do this. you have to do this in your graphic editor and then apply your filter to the area you want.
if you want to play with the alpha channel in FF use the 'set alpha' and 'get alpha' components within the editor, otherwise it's pretty much ignored. remember, just because the alpha is transparent doesnt mean it's not there or that something cant show in the other channels.
in a 24 bit image you have 3 channels, each is 8 bit adding up to the 24. when you add a fourth channel this is the alpha. it is also 8 bit, now adding your 24 up to 32. so, just because the alpha is blank doesnt mean the rest is.
this is a bit misleading. if your file type is 32 bit, like a .png or .tif and so on, you're not actually eliminating the actual channel. you may be ignoring it or removing data from it or eliminating it from use, but you are not actually getting rid of or eliminating it. the channel is still there.
IONclad
fair enough.
sometimes I forget that 32bit isn't part of the average lexicon. smile:|
33 unregistered users.
