fotocomics
Posts: 9 |
the plugin could be used only on PS or other PS compatible graphic editor (as photoimpact or Psp) could host it?
my gallery
http://stockmanipolation.deviantart.com |
| Posted: August 11, 2006 3:52 am | ||||
Posts: 3507 |
Host compatibility:
* Adobe Photoshop 6.0, 7.0, CS and CS2 * Adobe Photoshop Elements 2.0, 3.0 and 4.0 * Corel Painter 8 and IX * Corel PHOTO-PAINT 10, 11, 12 and X3 * Corel Paint Shop Pro X * Jasc Paint Shop Pro 8, 9 |
| Posted: August 11, 2006 5:52 am | ||||
fotocomics
Posts: 9 |
but installer install the plugin only in PS no option to install it in other host.
I must copy it from PS pugin folder to use another host or....? my gallery
| Posted: August 11, 2006 6:05 am | ||||
Posts: 3507 |
| Posted: August 11, 2006 6:52 am | ||||
Administrator |
Which host are you trying to install FF for? |
| Posted: August 11, 2006 7:22 am | ||||
fotocomics
Posts: 9 |
the installer's look is very diffrent on your testing machine then on my laptop. I never saw something similar to that screenshoot. There was only a box to check, with the option to install the plugin in PS, no option for other programs. ...but i solved the problem And i have 2 good news : 1)FF is supported also from Photofiltre Studio shareware(30 d. trial) really intuitive...and cheap (25E) ( from http://www.photofiltre-studio.com/frames-en.htm ) 2) one of the best image viewer(and converter) around XnView also could be used as host Xnview www.xnview.com is free for personal use it's very similar as quality, to Irfanview And i suppose also a Irfanview www.irfanview.com could be used as host (this i didn't try ) my gallery
| Posted: August 11, 2006 8:43 pm | ||||
Administrator |
For the hosts that are not officially supported by Filter Forge, you can simply copy the entire C:\Program Files\Filter Forge\Plugin folder to the plugin location of that host.
Since we test Filter Forge under officially supported hosts only, we can't guarantee that it will work on unsupported hosts (but in most cases it should). Also, since the FF installer doesn't know about the new plugin location, it won't uninstall it automatically, and you will have to remove these folder copies manually when you uninstall Filter Forge. |
| Posted: August 12, 2006 6:33 am | ||||
fotocomics
Posts: 9 |
Yes i get it.
On my sistem FF seem working very well also with PFS and Xnview my gallery
| Posted: August 12, 2006 7:45 am | ||||
