Semper Android
Hello,
I just purchased this software yesterday evening after testing over the weekend. Hats off to the developers on the product and the community. I can see how this filter development can become like crack very easily, but seriously I have a few lingering questions. Thank you to those of you who respond in advance.
I write Android applications and the application of Filters to create new and exciting icons when writing theming apps is the purpose that I can see using this tool initially. So a single filter would be used several times against my own set of 150 icons. With that said my questions are:
1. There seems to be some quirkiness with use on Macbook Pro running 10.6 where the plug-ins to Photoshop do not work. I saw some hacks on the wiki page, but they look to only apply to 32 bit Photoshop and I am running CS5. Getting FF to work directly from Photoshop is important as I use actions to automate the modifications to icons.
2. Can a FF design be exported to a photoshop filter directly after being created?
3. Is there a quick and easy way to mod an existing filter to only apply to a selection and leave the remaining image in Alpha state?
Thanks again in advance
Hi Semperdroid:
Welcome to the FF community. I don't know about macs, but i can answer your other questions:
2. If you mean make a stand alone filter (.8bf compatible file), the answer is no. Lots of new people ask this. Saving out exporatble stand alone filters would put FF out of business, so it's reasonable they don't offer it. (Also it would be all but impossible to support technically to all the products which can read .8bf and update to new ff versions).
That said, the basic edition is comparably inexpensive (only $149), and you get access to the whole 7,000+ library of filters. That's less than many other commercial filters (not pointing any fingers *cough*) which offer less filter value for more cost.
3. Yes: use 'threshold' and 'get selection'. Put 'get selection' as your source, the old image 'external image' as the low input, and the filter as your high input. Note this only really works with image filters, not with surface filters (which is doable, but more complicated to describe, and depends on the input filter.)
Personally, I find it better to just create a duplicate layer in pshop, run FF on it, and then turn alpha into selection. Actually, I'll usally make multiple duplicate layer copies, and run multiple FF filters on them, and then blend between them to get a nice end result.
Semper Android
Thanks I appreciate the help.
Does the suggested workaround for your 32-bit version of CS5?
For automated actions you can also try the batch renderer.
Totte
Übernerd
Filters: 107
I wrote a batch render controller for Mac OS X, you can find it here:
Batch render thread
Semper Android
Someone pointed it out to me. Great tool. Thank you for the help.
37 unregistered users.
