as a beta tester i'm used to getting more builds to test than are currently being done here with FF. i'd suggest putting out more builds. i know a lot of things have been discussed and i'm quite sure you guys are fixing all sorts of things and adding new things and so on, but the problem with the current system here is that if there are a hundred new things to test in the next release as opposed to 10 new things, there's more of a chance for bugs showing between each release. if more releases were done we might be able to catch some things that would otherwise be lurking for a long time.
i'm used to about one new release every week or two. bugs always get fixed first and new features are addressed secondarily. it's a lot easier to compare fewer fixes/new items and so on if there are fewer to do so but that come more frequently. it's also less devastating if there is one really critical bug that might mess up a lot of things. by waiting a long while between releases this really critical one can affect a TON of work as opposed to just some work.
also, this can play into when you actually do your public release of FF. it's not uncommon for software houses to get the major bugs fixed and then add things or even fix other things after the first public release. it's not necessary to have every feature imaginable in the first release. now, nobody likes buying buggy software that takes 6 upgrades by the consumer to get to a point where it's actually decent software, so i'm not recommending that in any way. but, there is a point where, if all the major bugs are fixed and you've got good features and you've taken into consideration the public needs and wants, it's ok to release the first public build.
FF had a number of critical crash type bugs to begin with. feedback was given and we're really not seeing many of those now or, we're seeing the same ones posted about. so, those bugs get fixed, a new release is done and we see if we can find other major bugs. this could have all happened, probably within the first month of going public beta. a new release would have been done and those fixes tested and by then a lot of new feature ideas would have shown up and some of those could have been incorporated with a new release and tested to make sure no new bugs showed up and that the consumer liked the new features. you then just rinse and repeat until some point where you go, 'this is good!' and oddly, this point is usually pretty obvious. i've seen it happen; things are getting better and better and all of a sudden almost every tester at once will post 'ok, this is good enough for release'. there seems to be a public acceptance level that seems to be almost a hidden sort of standard. few could tell you exactly what that is, but when they see it, they know it and they'll tell you about it.
so, basically, this is a whine for "I WANT THE NEXT RELEASE!!", "I WANT THE NEW TOYS!!" smile:)
annoying, arent i, vlad smile;)
craig
onyXMaster
Filter Forge, Inc.
Agreed, but there are reasons that it's not this way.
_Most_ of the discovered bugs were fixed within the first two weeks after the release, and we could release the new build at the end of July (I voted for early release internally, and kept telling every week "Test it and release it").
But, we decided to implement several important features, that may break existing functionality. Better we do them and release as a single build, rather than stretching them along two months, making users unhappy with _several_ breaking changes.
Adding to this -- we still need to do some internal testing before release which takes at least the same time as to develop the feature or devise a bugfix.
Also, I've fixed the very bad synchronization bug (which was known right after the release) only a few days ago smile:)
No hard release date is set, but it _may_ be released around the end of the next week (I know I told similar things before, hence the "may be").
onyx, thank you. we sitting on the outside never truly understand all that has to go on on the inside. but if i just had ... smile:)
craig
If memory serves, that was the last known Access Violation bug on our list. It was very, very elusive -- we have even bought a dedicated P4 HT machine to catch it.
onyXMaster
Filter Forge, Inc.
And, as a sidenote, it was caught on my development machine, not on the bought one smile;)
Your wish has been granted smile:D
http://www.filterforge.com/more/news/966.html
Nice I just downloaded it but not yet had a chance to play wih it. Thats later tonite when I get a moment. Congrats on the progress so far. smile:D smile:loveff:
hehehe, vlad. now i can stop bugging you for a while smile:)
thank you, FF team!! it's an amazing build!
just a note here. to get the new build, hit the 'download more filters' button and you'll get a response of something like 'you need the new version to access the filter library. would you like to do this now?'. just hit yes and the new version will start downloading. it's 25 megs, so be prepared. once it finishes downloading, FF will close down and an install wizard shld start up to install the new version. you shldnt have to do much here at all. just accept the end user agreement when it comes up and wait for the install. once it finishes it will tell you. hit the 'finish' button and it's done. you will have to manually start up FF after this; it wont just restart on its own. also, the new version already knows where your old version is from the registry in windows, so you dont need to hit any browse to locations or anything like that.
craig
28 unregistered users.
