Dizzie
I just opened the program. When I went to download more filters it said I needed to upgrade...so I did. I Opened the program and went to download new filters. I am seeing several filters with "Upgrade Needed" stamped across the thumbnail and in the preview pane it says "This filter cannot be displayed. To use the filter, download the latest version of Filter Forge."
I just upgraded...what's wrong? I am using Basic v 1.020
Lorenzen
Filter Forge addicted
Filters: 66
Hello Dizzie
Perhaps it's an upgrade to version 2.0 it means??
Dizzie
2.0 is a Beta version...the latest version is 1.020
It depends on what filter you downloaded..Some are made with version2 which are not compatible with version1.....
Dizzie
so are you saying some filters are made with the Beta and I have to install the Beta to use them...the latest version is not good enough?
Lorenzen
Filters: 66
Yes that's right smile:)
Well, you're using the filter download method that is clearly marked as obsolete smile;)
The web pages of these filters show the 'Requires Filter Forge 2.0' text.
Dizzie
Thanks for the Info!
