Hello to everybody in the forum, as this is my first time here, and have just bought FF 1.0 and have been using it for a while in test.
I want to know what is most important in hardware for FF ?
Is it the CPU with multicore ?
Or is large amount of RAM ? Or both ?
And what about the Graphic Card ? Is it important for FF ?
I want to buy a new computer in the near future and want to know what makes FF speedier and be able to render faster.
I thught on an intel i7 920 and 12 GB RAM with one of the new Nvidia Graphic cards with Windows 7 64 bit.
Now I have an AMD X2 4400 with 4 GB (well really 3 GB as it is 32 bit) and Nvidia Geforce 9600GT with 1GB RAM onboard with Windows XP 32 bit.
I know it would not work faster on Windows 7 64 bit because it is 32 bit but I think it could benefit from having 12 GB RAM, or not ?
Thanks very much for your advice
KGtheway2B
KGtheway2B
Lots of CPU for speed.
Lots of ram for large FF images. (I think)
Gpu doesn't matter.
^^Speaking purely in terms of FilterForge
I've been shopping around lately, the i7 is a good choice. 12 GB might be a bit on the high side unless you find yourself running very ram heavy tasks, but it can't hurt anything (except your wallet.)
Definitely go 64bit windows. There are no drawbacks if running 32 bit programs.
As for video cards, it all depends based on what you are doing. Are you gaming, doing 3d modeling work, or just using photoshop?
Definitely the CPU. You cannot have too much of CPU power for Filter Forge smile:)
It can't. Filter Forge never uses more than 1.5 GB RAM, regardless of its overall amount, regardless whether you have a 32-bit or a 64-bit OS.
Thanks very much for your answers
I Know that 12 GB is a hugh amount of RAM but as I will be using it with large images in Photoshop so as GMM said for FF of CPU, You cannot have too much of RAM power for Photoshop. I am not doing 3D in this moment, but have plans to begin using Poser 2010 software. I will not buy a QUADRO card.
CPU POWER IS THE MOST IMPORTANT
So, raw CPU processing power is what is needed and most important for FF to work faster.
I think that like any other professional and power hungry software what is important is the speed of the CPU ( how many
Would it benefit from having 6 cores or does not go beyond Quad Cores ?
I have seen that having 6 cores (in AMD style) is not so important because there are other things that are important too that you can find in intel i7X980 6 cores and are not in the AMD 6 cores as you can see here that AMD 6 cores is behind many quad cores.
http://www.cpubenchmark.net/high_end_cpus.html
GPU DOESN´T MATTER
I think that perhaps the GPU doesn´t matter because FF does not have yet any GPU accellerated programing with Open GL or CUDA, like other sofware are having now or like the new photoshop.
Will in the future FF have support for GPU accelerated programming ?
RAM IS NOT IMPORTANT NOW
If Filter Forge never uses more than 1.5 GB is like the previous photoshop version and other software that can´t use more memory because they are in 32 bit, so I think that the only way to be able to use more ram is to convert FF into 64 bit, but:
Would FF 2.0 benefit from having more ram available if it was 64 bit optimized ?
I mean if it would be able to use ore ram to go faster and smoother although as said the CPU is most important
Totte
Ubernerd
Filters: 107
Cores, the more the merrier - all I can say.
Yes, Totte I think also that 6 cores is better than 4 cores or 2 cores, BUT is not as easy as that, because it greatly depends if the software and OS can be able to use them and get benefit from them or not, I mean if they are made and optimized for multiple cores.
Also is important to have a balanced computer and not just a 6 core computer with 2 GB RAM, a slow or bad hard drive without defragmentation, and things that make a bottleneck in the computer.
Also is important the PRICE, as intel i7X980 cost more than 900$ or 900€ so the benefit speed amd perfomance you would get from having a 6 cores is not justified with the price, you could get probably in every day tasks much more speed and perfomance buying a i7 920 or 940 and buying more ram and a SDD drive for the same price of i7X980
And as said before, AMD 6 cores is much cheaper at +300$ but it does not give the same perfomance that could give the intel, and is even is nearly the same level than a quad core inte perfomance.
Totte
Ubernerd
Filters: 107
FF Uses all my 16 cores (or more correctly 8 cores, with hyperthreading)
It depends, for me, FF is a hobby, but I got a huge machine for software devs, so I got the cores already. But FF runs pretty good on my dual core i7 also 4 threads with hyperthreading, but depending on filter, the 16 cores is between 2 and 4 times faster.
what's the reason for that, gmm? i can sort of understand it for an XP machine with the ram limits it has, but a number of us are going 64 bit in win7 and wouldnt the extra ram help render things a bit faster?
Thanks Totte, that is what I wanted to know, if FF is able to use all the cores of any multicore CPU even with more than 4 cores.
As you say it uses all the 16 cores (or more correctly 8 cores, with hyperthreading), so it is very good.
By the way, wich 8 cores CPU you have ? Or do you have 2 quad cores ?
I know also that is not only important the number of cores, but also their speed, because a Quad Core at 3GHz would be faster than a Six Core at 2 Ghz, this also happened before that some high speed Dual cores are faster than some Quad Cores.
And speeaking of FF, I think that what is important is a high GHZ, and having more cores is even more better.
As far as I know, this is a problem of the application not being optimized for 64 bit, and can not use more than 1,5 GB on 32 bit OS. And as you say if you put it in the 64 bit OS where there is not a limit for the memory the the OS is able to use, I think the applications still runs as a 32 bit in 64 bit compatibility mode, so it the same. It needs to be a native 64 bit application to use more ram.
Please, correct me if I´m wrong, as I do not know much about this.
This thread here in this other forum I found on google could help, as it says that Windows gives 2 GB to 32 bit apps.
http://www.techsupportforum.com/micro...n-2gb.html
Totte
Ubernerd
Filters: 107
Two quad cores, MacPro
FF was designed to utilize only two cores, right??? Was the FF framework redesigned to now utilize more than two cores??? If FF can only utilize two cores, then obtaining maximum GHz core speeds becomes the issue.....or you can get into overclocking, but that can be unstable.....
No, it utilizes all available cores, including the HT ones.
Totte
Ubernerd
Filters: 107
Here is a processor view, all 16 cores almost at max smile;-)
WOW !! very good to have 16 cores and that FF can use them all, and so it will be much faster smile:)
Regretably this is much more difficult to make on domestic computer for Windows VS the Mac you have. I wanted to buy a double socket CPU motherboard and was not possible to find one for putting two Intel i7 2600K Z68. smile:(
The only way I found is on expensive computers made especially for companies or workstations that have also dual socket and CPU but cost FROM 3000$ smile:( smile:cry:
stevedipaola
thanks all ( I am the original poster) - so more specifically for the geeks out there
I already have a Intel i7-9700K (CPU @ 3.60GHz, 3600 Mhz, 8 Cores) and need more speed for my current FF jobs - what is the best bang for the buck cpu I should get in a new system. I have been intel all my life but ready maybe to try AMD.
I just check with a benchmark site for adobe video editing (and one for photoshop) and it looks like that I have to pay twice the price in a cpu to make a dent from my current cpu - maybe I have as good as it gets without unlimited moneys: https://www.pugetsystems.com/labs/arti...2019-1633/
stevedipaola wrote:
maybe I have as good as it gets without unlimited money/
If you would really get faster CPU you would need to multiply the CPUs in your computer and not have just one
Yes, think you are right, that without unlimited money, you have the one of the best
the fastest computer available now is a Quad Cpu intel Xeon
Intel Xeon processor benchmarks
But of course is really very expensive as each one of the fastest Xeon cost 11.000 $ for each one (44.000 for 4)and you need a Quad cpu motherboard that cost about 499$
Here is the newest (from 23 June 2020) CPU comparison between Intel and AMD and it seem that your i7-9700K is really among the best ones you can get because it gets a 96.77% ( 100% is the maximum) so you would not see any difference buying the faster 10900X
CPU Hierarchy 23 June 2020: Intel and AMD Processors Ranked
Yes, you are right, that as it is now, according to what you have, you would need to spend on the expensive 1999$ AMD to get a noticeable difference in speed from your own 9700K, so really for now there is no available faster CPU that is affordable better than your own 9700K that could make a difference in speed in FF
Thanks for the link , interesting and useful to know
TURNING OFF ANTIALIASING FOR PREVIEW HELPS MAKE IT FASTER
Apart from buying a new computer there may be another workaround that maybe could help in some way
You could use for previewing and testing settings to turn off the anti-aliasing
See the last post of this thread
I have found this CPU comparison that is from May 2020 about the best CPU for workstations but they are expensive as usual for a powerful computer
Best workstations CPU of May 2020 by Anandtech
Sometimes choosing a CPU is hard. So we've got you covered. In our CPU Guides, we give you our pick of some of the best processors available, supplying data from our reviews. Our Best CPUs for Workstations guide mostly covers workstation processors available to consumers, although some server products cover both segments.
I think I can confirm that what you have said is right, with the Intel i7-9700K (CPU @ 3.60GHz, 3600 Mhz, 8 Cores) you have seems to be a powerful cheaper and affordable CPU according to this professional benchmark that shows that your 9700K has 22.5 points and the only next option for just a single CPU computer is intel 9900K (488$) that is 26.5, but it would not make much change from what you already have
Benchmark comparison between single and multiple CPU computers from 2019
The only way to make a change is to have a multiple CPU computer but this of course is much more expensive
Here I have just found an interesting and useful long explanation about what is a good computer to buy in 2020 for 3Drendering, that as FF, is the software than needs more power
Best buy workstation for 3d rendering performance
See screenshot below
GMM wrote: in 2010
I have to say that it seems that it has never been told here that FF is now able to use more than 1.5GB RAM and can be configured on options
