GQP
Posts: 3 |
Is it possible to move the filter library (FFXML files) to another location/directory?
I found a few threads that were from 2006 that stated that this feature would be added, but I can't seem to find it. In WinXP, the filter library is currently located in C:\Documents and Settings\%Username%\Application Data\Filter Forge\Library, but I would like to move it to another drive (where I store all of my data that is backed up on a continual basis). NOTE: I have Filter Forge 1.x |
| Posted: April 20, 2010 6:30 am | ||||
Posts: 3507 |
Do you need to create a backup of the library filters?
You can copy the contents of the following folder: %APPDATA%\Filter Forge\System\ (by default it is C:\Documents and Settings\YourUserName\Application Data\Filter Forge\System) |
| Posted: April 20, 2010 6:35 am | ||||
GQP
Posts: 3 |
Yes, I understand that I can make a copy of that directory.
But I have set my system up so that all of my "data" is on another drive. That drive is then replicated on a continual basis to a third drive and backed up to multiple locations. I would rather not modify my backup and replication routines for every application that I purchase. It would be much better (and user-friendly) if I could relocate the filter directory to another location on my "data" drive (which is already backed up and replicated on a continual basis). So the question still stands - Can I move the filter library to another location? |
| Posted: April 20, 2010 6:46 am | ||||
Posts: 3507 |
You can move the whole user profile as described in this Microsoft KB article. Filter Forge will always use the %APPDATA%\Filter Forge folder, wherever the APPDATA variable points to, this behavior cannot be changed. |
| Posted: April 20, 2010 7:30 am | ||||
GQP
Posts: 3 |
Thanks, but I don't think that asking the customer to hack their registry is a great workaround! In my case, there is over 3 GB of data and almost 15,000 files in the %APPDATA% section on my computer. So moving all of that data is not something that I wish to do, nor does it make much practical sense. All I want is the ability to store the filter library presets (XML files in the My Presets directory) to another (user-defined) directory. This way I can work the files into my disaster recovery plan (just in case). As I stated in my initial post, there are threads from back in 2006 where this feature was discussed and statements were made to the effect that it would be added into a future release. Is this still the plan? This should be a relatively easy fix. I'm not sure what the reluctance or holdup is. |
| Posted: April 20, 2010 4:35 pm | ||||
sandmanmax
Posts: 1 |
I'm resurrecting this thread! There's another VITAL reason for adding this capability to FilterForge. My C: drive is a 238gb SSD and I don't want to clutter up precious space with data. Please allow users to relocate our filter files somewhere else!!
| Posted: January 14, 2018 5:09 pm | ||||
yeah, this would be nice. I'd even like it if we could do backups through FF to an even other drive and have that done on a schedule.
| Posted: January 31, 2018 1:43 am | ||||
| David Roberson |
Sounds like something to add to the Feature Wishlist.
| Posted: February 7, 2018 2:35 am | ||||
