Nicola Y.
Nicola
Hi,
I'm new here and I wonder how to get to the filter library...Do I have to install the beta version on the PC first. The PC I'm going online is very old and I don't think I can run the program there...I have a second PC for which I'm working with...
Yes, in order to download and use the filters you must first install the beta software.
James
James
Filters: 46
I have exactly the same problem as you my net pc is an old computer and the program freezes up and stuff when it renders the texture previews and the selected texture, it would be nice to have the option to turn this off so i could just use FF on this computer for when i want new textures, You will be pleased to here that if you can hopefully run the program, go online and download filters you will be able to transfer the downloaded files to your good computer. smile:)
Nicola Y.
Nicola
Thank you both for your answer. I installed it now and download the filters. My old PC has to work hard with the previews and I will do like you said James. I will transfer to my good PC now. smile:)
Nicola Y.
Nicola
New problem...I tried to transfer the downloaded filters to my other PC, but they are not showing...aren't they located in the Resources folder? I copied the whole folder from my old PC to the other one smile:| Help please!
Nicola, to find out where the filter files are located, select any filter and press Ctrl+L (or choose Filter > Locate File from the menu). This will open an Explorer window showing the location.
Nicola Y.
Nicola
I don't know why, but it doesn't work for me, but I fixed the problem..I connected my other PC to the net now and downloaded the filters. I love the program! Fantastic possibilities! smile:)
