meyendlesss
Filters: 32
Will the HDRI import be able to effectively use all CPU cores?
Right now it only uses ~15% max on my i7 920.
Still gets done fairly quickly as it's running @ 4GHz, but would be great if it could use 100% CPU.
Igor Lorents
Filter Forge, Inc.
Currently the HDRI import is single-threaded, that's why it uses only about 15% of your computer's processing power.
Multi-threaded version is a low-priority task on our TODO.
meyendlesss
Filters: 32
It's not really important, but it would be nice.
The import process is just too slow even with a decent overclock.
25 unregistered users.
