Amy Hutton
Posts: 26 |
Can the disk that I got when I ordered Filter Forge be used directly with psp as plugins, or can it only be used with the stand alone program?
If that is the case, is there any way to download all the filters so they CAN be used as psp plugins? Amy Hutton |
| Posted: November 12, 2009 11:53 am | ||||
Hello Amy and welcome to FF..
You can use FF in either a stand-alone application or as a plug-in itself....The filters are just an extension or expansion of the FF plug-in..... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: November 12, 2009 12:10 pm | ||||
hi amy,
CF is right and, if you have psp installed before you install FF, FF shld find psp and install itself as a plugin. there's an .8bf file that gets put in the 'plugins' folder of psp. if that doesnt happen, or if you install FF and then psp, you can manually move the .8bf file into the psp 'plugins' folder and it shld work then. the individual filters never work without the main program. so, you dont install the individual filters into psp. you do as above and simply download the filters to FF and when you call up FF from psp, it will look the same as when you load FF by itself, so all the filters you have in your personal library will be there regardless of if you loaded FF from psp or as a stand-alone. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: November 12, 2009 1:13 pm | ||||
Amy Hutton
Posts: 26 |
Let me start over. I have had FF up and running as a plugin for a whle now. I just now got the CD with all the filters in the mail.
Now, running ff from psp how do I access the filters on the CD? Say I have a "fodder" image up in psp and I'm looking for a filter on the disc, that I haven't downloaded into ff from the webpage. How would I do that? RIght now all I know how to do is to save filters to ff from the webpage. Amy |
| Posted: November 13, 2009 2:34 pm | ||||
amy,
to get filters to show up when you call FF from psp, you need to put the filters into your FF 'my filters'. this can be found in windowsXP at c:\documents and settings\username(whatever your account user name is)\application data\filter forge\my filters . i think that's right. if it's in vista then it's c:\documents and settings\user name\app data\roaming\filter forge\my filters . phew! (windows is nuts on this junk). i'm doing those paths from memory, so you may have to look around a bit, but that's the jist of it. once you have them in 'my filters' they shld work fine when you call FF from psp. FF filters MUST be within 'my filters' or they wont work. so, just copy the filters from the cd/dvd into 'my filters' and all shld be well If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: November 14, 2009 8:48 am | ||||
Posts: 3507 |
To extract the library from the archive on the disk, you can use this free utility: http://www.7-zip.org/
To import the filter library to Filter Forge, please copy the 'Filter Forge' folder to 'C:\Documents and Settings\Your_User_Name\Application Data' (on XP) or ‘C:\Users\Your_User_Name\AppData\Roaming’ (on Vista) and click 'Yes to All' if asked for confirmation. |
| Posted: November 16, 2009 4:50 am | ||||
ktvd
Posts: 4 |
I'm just about to place my order and am considering the filter CD. Can you sel ect just 1 or 2 filters fr om the CD to load into the library, or do you have to load the entire set of filters. I wouldn't want to do that - I'm sure I'll only want a few favorites.
| Posted: June 9, 2011 3:19 pm | ||||
Posts: 3507 |
Our general instruction tells how to load all the filters in the library.
In your case the best way would be to extract the disc content to a temporary folder and then copy the necessary files to Filter Forge 2\System\Library. |
| Posted: June 10, 2011 6:37 am | ||||
ktvd
Posts: 4 |
GMM - Filter Forge 2\System\Library - is that for Mac? I'm not having much luck and since I can't seem to download today, I thought I'd try the disk.
| Posted: June 16, 2011 1:24 pm | ||||
ktvd
Posts: 4 |
GMM- a little more info. I couldn't download, but I could browse the site for filters. I found a "cow" filter numbered #804. I referenced that number to filters on the disk I had purchased and found it. I pulled the Library_804-1.ffxml into the library of filters on my Mac that began with Library_208-2.ffxml. Back into Photoshop, the filter did not show up. So I closed and started again with a new file. Still no filter. I'm sure it is an easy fix - I just don't see it.
Thanks |
| Posted: June 16, 2011 1:45 pm | ||||
Posts: 3507 |
Please be more specific: where on Mac? You need to put this filter into /Users/your_username/Library/Application Support/Filter Forge 2/System/Library (for Mac). |
| Posted: June 17, 2011 9:39 am | ||||
15 unregistered users.
