Amy Hutton
AHutton
I just bought FF. I use PSP X2. I'm guessing I should run the setup file and place the resulting files into my PSP plugins folder, right?
How do you set this up and use it? I know....duh, right?
Amy Hutton
Usually FF installs the plugin portion for you...Then from there you can either open FF as a stand-alone app or access it directly from within PSP as a plug-in...Once you have it running you can always ask more questions...Welcome to FF btw.... smile:)
If it does not install the plug-in portion it can be found here in the FF directory.
C:\Program Files\Filter Forge\Plugin
Using the "windows" version...Not sure of the Mac version.....Then simply copy these over to your PSP plug-ins folder.....
Then have fun..... smile:D
hi amy,
dont i know you? your name is ringing bells in my head.
CF has it right. if you already have psp x2 installed, FF shld install it's .8bf files automatically, but if not, follow CF's instructions.
Amy Hutton
AHutton
Hi, Craig, you do know me from retouchpro.com . For a while now I've been fixated on creating abstract images. (A few years actually.) These filters should help a lot. I love distortion filters, and I think I've hit the jackpot.
Amy
ronjonnie
Designer / Artist
Filters: 320
Good morning Amy, smile:)
Welcome to the Filter Forge Family!
You will love it here!
CF & Craig are right on! Lots of help here with the Filter Forge Team of friends. I know you will enjoy making filters. It is truly addictive. I wish you many happy days of enjoyment.
Have a GREAT day!
Ron
ah, there we go! i knew i shld know that name smile:)
yes, filter forge has some great distortion filters. just do a search on voldemort and you'll be in heaven smile:)
