WiredMarys
WiredMarys
Hi, I hope someone can help me out here. I own a license to the Basic version of Filter Forge. I recently moved all my plugins to my External Drive. When I did that, Filter Forge will no longer work for me. I want to just do an uninstall and reinstall it rather than copy over(since that didn't work). My problem is, I don't want to lose the library of great filters that I've gathered. If I just save the Library folder that is there now and replace the new one with that folder after I get the program installed, will that work? Thanks so much for any help.
Clicky! smile;)
WiredMarys
WiredMarys
Thank you. I think I see now what I need to do. smile:D Will give it a shot smile;)
WiredMarys
WiredMarys
smile:banana: Thank you thank you. Worked great!
We should definitely give more visibility to the Wiki. I'd give it a top-level slot in the menu, but we had only one, and it's already allocated for the Gallery. Perhaps adding a prominent link above the list of forums would do the trick?
I think you might be able to squeeze another tab in up there......or maybe even widen the page......lots of unused space to each side of it, eh??? smile;) smile:)
You could always remove the word 'Homepage' from 'Filter Forge Homepage'.
27 unregistered users.
