IXIMAGES
I had FF Basic installed onto my laptop and, well, to make a long story short, my daughter broke the screen. I bought a new computer and would like to install FF on it.
My laptop works, barely...is there a way to put my FF with all my filters onto my new computer without buying a new version?
Thank you!
KGtheway2B
KGtheway2B
To get your filters back: You should try hooking the laptop to an external monitor to view what's going on and copy over your filters (Press ctrl+l to view the files themselves) OR: just take the hard drive out and copy it over manually that way. (Bit more advanced technique though)
To get FF back, you don't have to buy the program again, just find your serial code (maybe search through your email?), download the demo and pop the serial key in there. You're good to go.
If you lost your serial key, I'd recommend contacting filterforge inc through the "Contact" tab at the top of the website. They usually get back to you within 2-4 business days.
Good luck!
IXIMAGES
WORKED PERFECT!!!!
THANK YOU SO MUCH!!! smile:)
