mcarr1973
mcarr1973
Hello All,
Does anyone know how else I can download a filter from the Filter Library?
When I open filter forge and click the blue link to the filter library:
http://www.filterforge.com/filters/
and click the button that says:
Open in Filter Forge
I get routed to another page that says:
"Filter Forge Is Not Installed
To open filters, you need to download Filter Forge and install it on your computer. If you do have Filter Forge installed but still see this page, make sure that cookies are enabled in your web browser and click here."
The click here link at the end of the above paragraph takes me back to the same page.
I Do have cookies enabled,.
So I dont know how to get filters from the library, if anyone else knows of a way other than clicking the open in filter forge button, could you please explain or give me some direction.
I would seriously appreaciate it!
sincerely,
Michael
mcarr1973
mcarr1973
Ok,
I got it now smile:) my apologies I have to use firefox for some reason safari dosent want to open it?
I thank you all anyway.
As an alternative: Under Tools > Options > Online you can find the...
Built-in library browser (obsolete) – Filter Forge provides access to the Filter Library via the built-in library browser. A hyperlink to the Library in the upper-right corner of the Main Window is replaced by a button that opens the built-in browser. This option is provided for compatibility with the older versions of Filter Forge. Also, the built-in library browser might be useful if you wish to download multiple filters at once.
35 unregistered users.
