grezmel
Hi All,
I appear to be having a problem with some settings - please see attached image. The effect does not appear to be working on the bottom section of the image.
Can anyone offer any advice ?
Thanks
Grezmel
Hey Grezmel......It would seem that a profile gradient is being used to disperse the effect.....which unfortunately, is not proportional to odd sized images.....only works for square images in that capacity.....
ThreeDee has a good workaround snippet filter called "Proportional Gradient"......I believe......
Grezmel, many filters are made to work primarily with square images, so there are two things you can do.
A) Modify the filter using the Proportional Gradient Snippet.
B) Resize the canvas of the original image (in Photoshop or other image editor) to a square, run the filter and then crop the image back to its original dimensions.
TD
