Henry The Mad Hedgehog
I have just done a re-install of my puter, and on re-installing FF i got this message from the anti virus ''attempt by Filter Forge Setup to connect to vip.cdn.cachefly.net' and do i wish to allow it, I choose no, and it installed properly... but i am curious what exactly is cachefly.net ??
Biomechanic
Filter Licker
CacheFly seems to be a 'streaming server solution' company
I would suggest that FF really didn't need to communicate with this site and your anti-virus package got it's knickers in a twist perhaps
J
The ZZ
Filter Forge and it's installer are never connecting to vip.cdn.cachefly.net.
Probably, your computer is infected with a trojan or other malicious software. Check it with another antivirus software.
Space... it seems to go on and on forever. But then you get to the end and a gorilla starts throwing barrels at you.
Hiya There
You could of course be right
I did a full scan with kapersky (with advanced rootkit detection etc ticked) and SpyWare Doctor and found nothing amiss, what the ''Integrity check'' caught was an attempt to connect to cacheflys servers at the time the installer for FF was launched, I was at the time doing a complete re-install so it is possible that its from another application, however both the web address and numbered numbered URL did check out with caheflys servers, so the warning was real. It matters little as the attempt in any case was blocked.
I will re-instate a disk image and try intsalling FF again with internet logging on, it is possible that the program i installed directly before FF was the culprit and that when i installed another program (namely FF) thats when the attempt was made.
I will let you know the results, I would also like to point out that it is because of the high regard which i hold the FF team in that i blocked the attempt and installed anyway, something which I normally wouldnt do with a program that i really thought suspect.
Andy
onyXMaster
Filter Forge, Inc.
I would like to suggest you to check your copy of Filter Forge Setup.exe, and even recommend to re-download a copy from this site.
it also may not be a trojan, but a call-home device/routine, which has become very common in software these days. and not all of those are malicious, for example, automatic updates to windows.
