yup, dilla was right. just got email notice that the new version is up and ready for download smile:)
Yes, we've released Update 1.011:
http://www.filterforge.com/more/news/986.html
The update fixes several resource leaks, so I encourage everyone who experienced slowdowns and crashes during long Editor sessions to download this update and give it good run.
smile:beer:
ssamm
Filters: 21
Very cool on the update. smile:)
After the update, I did attempt to put a "resource leak" (as I encounter it) problem to a test, and it did, sort of still fail. (That is, while editing/creating a filter, after a long while of time, where I also had my Windows Media Player play a CD from my disk drive (to suck up more RAM), I still ran into problems where the filter I was working on ran into the resource-leak bug where my filter was destroyed to a 0 kb file...)
The problem/error seemed to occur when, while in the Editor, when I clicked on the "save" option...
(But, uhh, I'm totally a fan of Filter Forge -- where I'm just responding to give some feedback. I.e. where "fuck it", there still seems to be an annoying resource leak somewhere...(?) -- but, where, meanwhile the program still seems to work nicely when using it to work normally with library filters...)
onyXMaster
Filter Forge, Inc.
I told the guys they shouldn't be excited about the leaks they found, since I was 99% sure it's not THAT leak, and it turns out I was right smile:D
so far, no crashes, but only one looong editing session since the new version. and i confirm that most of my crashes in the recent past come when you hit 'save'.
also, would a moderator be so kind as to correct my spelling on the title of this thread? smile:D 'version', not 'verion'. lol.
GMs Apprentice
Hm, having problems with the update:
Error: The program cannot run update installer
(error code 0x000002E4).
Please update Filter Forge manually
DownTheShore
Got that same error myself.
Had same problem, 3rd time worked smile;) smile:)
That still exsists in the update. I had it happen today. Hitting the save after FF was getting sluggish resulting in a crash..The old resources bug.. smile:| smile:cry:
Thats funny it's not one of the problems I have, I wonder if your cpu power effects this smile:| smile:)
onyXMaster
Filter Forge, Inc.
This bug tends to manifest itself _much_ more often on multicore/multi-CPU machines (due to its roots laying in wrong inter-thread synchronization), so, yes, the CPU "power" affects this smile:)
GMs Apprentice
Still not having any luck updating. Has anyone done anything other than trying multiple times?
GM Syndicate, try downloading filters. that will trigger the update mechanism. that's how i updated mine. it will start the download and trigger a new install shield to pop up while it shuts down FF. once the update is completely installed you can then start FF again.
pixel8ted
GM,
I have a Core 2 duo and couldn't update using the FF updater. To update, I downloaded and installed the newest FF exe.
http://www.filterforge.com/download/
Terri
onyXMaster
Filter Forge, Inc.
The 0x000002E4 error is specific to Windows Vista and is triggered by the restricted security stuff (UAC/elevation/etc.).
As far as I know, it was fixed in the 1.011, but the 1.010 cannot update automatically since it still contains broken code. If you tried to update, but stumbled upon the 0x000002E4 error, try going to "%APPDATA%\Filter Forge\Updates" folder (you can paste the quoted text with quotes into the Start->Run... box, and run the update manually.
If the update file is not there, you always can download the latest version from the site (see Download tab above) which will happily update your installed version smile:)
