APT
Posts: 11 |
why do I have the message that say I have to update to install the filters from the web site. Isn't there a way to install filters manually into the library? I choose not to update my software, last time I did I had very many problems.
| Posted: February 13, 2008 1:01 pm | ||||
garbanzo
are you using a serial you got from some warez site? |
| Posted: February 14, 2008 8:37 am | ||||
APT
Posts: 11 |
what is a "warez site"?
I figured out where the filters are being stored when I download them. Thats really all I needed to know $300 for the pro of FF? wow, for a second there I thought I was at adobe.com |
| Posted: February 14, 2008 10:19 am | ||||
for what you are getting, i'd say that was underpriced. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 14, 2008 11:21 am | ||||
APT
Posts: 11 |
Maybe thats true,no graphic program can compare to Photoshop CS3, so really its worth the money, if you have it.
The verdict is still out for filter forge, I haven't quite got the hang of it like I do PS. It seems to have potential, with some practice we will see about that $300. |
| Posted: February 14, 2008 11:34 am | ||||
onyXMaster
Posts: 350 |
Actually the Standard edition which probably will fit most of your needs is $159 with the current discount applied
| Posted: February 14, 2008 12:23 pm | ||||
onyXMaster
Posts: 350 |
Also, I would like to note that if some components are changed between versions, your filter location knowledge (just press Ctrl-L in FF when filter is selected, I recommend you to stick with "My filters" location only, since fiddling with library filters storage may lead to some non-easy-to-fix problems like FF refusing to start at all) won't help you much, since the code for the new components' version just isn't there
| Posted: February 14, 2008 12:27 pm | ||||
onyXMaster
Posts: 350 |
Ah, and the last one -- we certainly would like to hear from you about problems you experienced when you updated FF so we can fix it. Please use the contact form to get a timely response if you have problems with FF.
| Posted: February 14, 2008 12:29 pm | ||||
i was referring to the cost of FF, not cs3 If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: February 14, 2008 1:28 pm | ||||
APT
Posts: 11 |
that was a pointless "quote" I was comparing, not referring.
I guess you didnt understand my post, oh well...onwards on upwards |
| Posted: February 14, 2008 1:34 pm | ||||
ah, i see it now. ok.
| Posted: February 15, 2008 9:08 am | ||||
