Messages 1 - 45 of 49
crazycase
Posts: 2 |
Filters with the username in front kinda bug me.
Sure it makes sense if a filter is similar to another one, but that rarely is the case. It also seems like filters named as such are typically of much poorer quality; maybe some individuals need to worry less about the glory and focus more on producing better filters. I'd be more impressed by a handful of well thought out texture filters then a flood of less than exemplary works, who's names just so happen to share the first part. Quality over quantity guys, the filter library already has enough filters that won't see much use, there's no need to bury the good ones even deeper. Sorry that I come off as a bit of an a-hole, this has just been nagging me for a while and I had to vent. |
| Posted: October 5, 2007 1:23 am | ||||||||||
there actually is a very valid point to using one's own name as the first part of a filter, organization. it's much easier to find one of steve's filter, for instance, when all of steve's filters start with 'steviej'. with filters in the library approaching 4000, finding filters is becoming cumbersome. i've frankly thought about re-submitting all of mine with my name as the first part. just easier to find.
| Posted: October 5, 2007 1:53 pm | ||||||||||
Thanx Craig, I'll take it from here.....
This is definitely a personal attack that they obviously intended for me to see......
I have to agree with you on that one!!! First, no one is forcing you to use my filters.....if you don't like them because I put my name on them or you think that they are "less than exemplary works".....then you are free to not use them.....it's as simple as that..... Second, your under a huge misconception if you think that a more complex texture filter denotes a more useful filter. It's all in the concept and usefulness.....without anything to do with how many components it uses. My "GlossEmboss2" filter got a high usage rank after only 26 downloads.....so there goes your theory...... Third, there are no rules here that mandate that you have to submit your best filter works. I just submit simple filters that I think users will find useful as simple effects or used as snippets to build more complex effects. I'm up to 14 or 15 high usage filters now......so I must be doing something right. Care to explain that, or is it just a fluke??? Fourth, I used some forethought with putting my name in front of my filters.....for the reasons Craig mentioned.....and to be able to keep the filter name if by chance it goes to a low usage rank and gets the 'kiss of death' so to say. If it does, I can improve the filter, take the "StevieJ" out of the title, and resubmit the filter with out loosing the best name for it. Comprendez??? Fifth, if this is nagging you so much and you have become such an authority on quality filtermaking, then why don't you make some filters yourself so we can all see how it's done by an expert??? ......instead of sitting on the sidelines complaining about how usernames are being put on "less than exemplary" filters.....that are being done for free by authors who already have lifetime updates.....even for unappreciative users like yourself.... Sorry for the "edge" guys.....but things like this bug me and I had to vent Steve
| Posted: October 5, 2007 4:49 pm | ||||||||||
ahimsa
I started adding my name to all the filters I updated so that they can be found easier. Maybe you don't like my filters, but others who obviously are using them will be able to find mine easier.
Another reason to add our names is because of certain people here who take other people's filters, change a color, and then claim the work as their own. You don't like mine...don't use them. |
| Posted: October 6, 2007 1:57 am | ||||||||||
This is a very sad post/attack and one that is filled with irrational thought -
name and quality have no junction, that is obvious from veiwing the popularity of filters in the library including Editors Pick
your account was only set up on the 5th, you are some one who set up a dummy account because you are cowardly unable to stand by your word under your normal user name - one will also not expect you to respond to any of these post, which is preferable as we don't need petty negative bitterness in the forum
yes you certainly proved that |
| Posted: October 6, 2007 3:00 am | ||||||||||
Oh come on, he's not trying piss people off, he's just speaking his mind. And frankly I do agree with him. I just think it's rather useless bringing the point(s) up because you can hardly stop it (since it seems a bit like a trend).
As for the reason for putting your name in front of the filter to make it easier to find. I don't get it, how's that? First of all, when I type in Sjeiti in the search I can easily find all my filters. So putting your name in filter name, or in the keywords for that matter, won't make the query any faster. Second, everybody has all his or her filters listed on a separate page. Third, and more importantly, when I'm searching for an effect to use I search on- or look for properties. I couldn't care less who made it, if the filter is good I'll use it (well of course I care about all you guys and girls out there but you know what I mean). I see putting your name in front of the filter name as a form of 'shameless self promotion'. I don't need it myself, but if someone else does I'm not gonna loose any sleep over it. I also agree with 'quality over quantity' but I also see that more as a personal preference: 'silence is golden'. I got tons of stuff lying around that I didn't submit that someone else probably would. But who am I to tell other people how to use FF. Besides, some of the low quality ones people submit are really cool and can trigger others to create great filters. As for 'burying the good ones even deeper': that's just something for the FF team to figure out. I know it's hard to make a good system that filters out the bad apples, and in FF's case there is definitely room for improvement, but not submitting filters for the sake of not 'burying the good ones' is a rather poor argument. |
| Posted: October 6, 2007 6:06 pm | ||||||||||
| jffe |
So what's the word, did we get an ip trace, was it a local ?
jffe Filter Forger |
| Posted: October 6, 2007 6:49 pm | ||||||||||
ahimsa
I did it to mine, not so they can be found easily in the FF library, but in the program library. It had nothing to do with self promotion. I have been thinking of an alternative instead of my name as it is too long and hides parts of the filter name when I look at them in the library (in the program, not here). I just like having all mine grouped in the program library so that I can have mine in the library section of my program and leave the My Filters section for filters I am working on along with snippets that I may be using to make them with. Sorry if you and the other one find this offensive, but you do have the option not to download mine if indeed either of you ever did. |
| Posted: October 6, 2007 6:51 pm | ||||||||||
To voice an opinion about filter naming is certainly legitimate but also very trivial - what is pissing people of is saying people who take this approach make substandard filters
so yes this is an attack/pissing off on the people putting there name first - as far as i can see this hypothetical glory? derives not from the name, but from the quality of the filter, the name is irrelevant |
| Posted: October 6, 2007 9:26 pm | ||||||||||
ahimsa
I see the insults about the filter quality as attacks too. If you two don't like our filters, don't download them, but to come in here and call our filters trash because we dared to add our names to the filters makes you both trolls.
| Posted: October 6, 2007 9:30 pm | ||||||||||
Oh contraire.....that's exactly what this guy/gal intended to do!!! What kind of user (if that's what he/she really is) goes out of their way to create an account just to complain about authors putting usernames on their filter titles??? Why would that aestetic in a filter title even matter to a user??? Don't you find this a bit "askew"??? The thing that really struck me as odd is......how could anyone think that an author gets any "glory" (or any positive value) by putting their name on a crappy filter??? Wouldn't that have the opposite effect by turning users away from all of their filters??? I don't think it takes a rocket scientist to see through the "just voicing an opinion" facade to the actual intent of their post.....hit-and-run dummy account.....and aren't coming back to defend it.....
Much less of a "shameless promotion" than starting the comment string on your own filters and posting sample pics to sell it.....which we are all guilty of, right??? Steve
| Posted: October 7, 2007 12:07 am | ||||||||||
| jffe |
Well sheesh, Stevie, now I feel left out, I never got around to doing that "jffe Du Spectacularre" filter series I was gonna ha-ha.
| Posted: October 7, 2007 12:33 am | ||||||||||
I'm actually not upset about it at all......just defending the integrity of my simple filters from a "heathen infidel defier"
LOL.....Steve
| Posted: October 7, 2007 12:49 am | ||||||||||
When did you say you were releasing this??? Steve
| Posted: October 7, 2007 1:17 am | ||||||||||
i tend to agree with sjeiti about let's not go overboard here. there are several folks who do this, put their names in the filter names. he didnt, after all, name any one in particular.
on the other hand, i think you have to expect a bit of harsh treatment when you come into a friendly forum and your first post is a rant, even if a small rant. not a good way to endear yourself and make yourself welcome. as for the names themselves, sjeiti, i was referring to use in the program, not the library. yes, all sorts of ways to search in the library. but, in the program, that's different. no search functions. so, when i want to add a particular type of effect and i know it's a glass type effect, i can just go to 'steviej' in the creative category and there ya go. it's also a bit exasperating in the program when folks use cute names or non-descriptive names for their filters. you've maybe seen the filter once when you downloaded it and say it's a fire effect filter. you remember that much of it. but, try to find that when it's named something like 'hell's inferno'. you dont remember the name, you dont remember the author, you only remember it had something to do with flames. so, you go through the various categories looking for 'flame', 'fire', 'torch', 'scorch', 'light', 'hot', and who knows what else and cant find the bloody thing. had you at least known the author you could find it a lot easier in the program. and this happens even in the library, though not as often. so, frankly, i'm all in favor of folks putting their user names in their filters. anything that will help me find what i want easier, is good with me. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: October 7, 2007 2:11 am | ||||||||||
ahimsa
Stevie, Foxxee, me and who else?
| Posted: October 7, 2007 2:14 am | ||||||||||
not my turn to keep track. go look.
| Posted: October 7, 2007 2:20 am | ||||||||||
ahimsa
What for, it doesn't bother me if people have their name on their filters.
| Posted: October 7, 2007 2:21 am | ||||||||||
| jffe |
----Well, not like you don't know this, but for the most part, you can search via keywords and usually get pretty close. I mean, most people do include a couple of relevant keywords with their filter descriptions. jffe Filter Forger |
| Posted: October 7, 2007 2:22 am | ||||||||||
True.....but I stand out like a sore thumb in that department.....and if I were a betting man, I would have to put my money on that being a thinly veiled dig at me and my filters..... It's really not worth saying anything about.....because what kind of anal moron would get upset with authors putting their name in the filter title??? Steve
| Posted: October 7, 2007 2:44 am | ||||||||||
ok, subject covered. time to move on
| Posted: October 7, 2007 2:53 am | ||||||||||
***as Craig, jffe, Carl, and Ahimsa drag StevieJ away still swinging***
LMAO......Steve
| Posted: October 7, 2007 3:05 am | ||||||||||
Oh the naming is for inside FF programm. I misunderstood there then, probably because I never use it. I always go online, search for it, and re-download. So all this is more a flaw of FF than it is a naming issue. If there would be a good keyword search in the library in the FF programm than none of this thread would have happened. Well I'm sorry I used the word 'shamelss' then, this being such a touchy subject.
And yes I do agree that the first post here was rather tactless and cowardly. But he did say sorry in advance and I'd rather give people the benefit of the doubt. Although he/she/it is keeping awfully quiet now. And I find 'starting the comment string on your own filters' a bit dubious too. But like I said: who am I to tell others how to use all this. And Ahimsa... let's keep it a bit civilized. Calling me a troll like that is not very nice. I am not attacking anyone in particular here. I never said someone using the author name in the filter name would make bad filters. It's two totally different things. I just think naming conventions are there for a reason and putting the author name in the filter name generates noise. But that's just my programming background, an opinion. The bottom line is: we all want a better search in the library. |
| Posted: October 7, 2007 4:42 am | ||||||||||
ahimsa
To me that was very insulting presuming that you know that the only reason we used our names was for shameless promotion. I'm legally blind and sometimes when I am looking in the library I can't tell if I am looking at one of mine or not. |
| Posted: October 7, 2007 4:54 am | ||||||||||
Hey Manon, I don't think Sjeiti meant any offense to us "usernamers"
I never looked at putting my username in the filter title as having any kind of glory or promotional value to it at all.....but maybe it would if my name became synonymous with "exemplary" filters.....so maybe I should take entRo's comments as compliments since they think I'm getting "glory" from it I think that people put their names on them for all kinds of other reasons as well.....sometimes to drive home that it's their filter creation.....sometimes out of pride over their work.....sometimes like putting a vanity license plate on a car......and other times just to be to cute with the title...... On top of the other reasons why I do it (stated above).....I keep the "StevieJ" off of a filter work in progress.....then, when I have it all polished up and ready to submit, I slap the "StevieJ" in the title to segregate it from all the other "work-in-progress" versions of it and to denote that it's a finished version. It comes in handy since everything has to all be piled into "My Filters", I have miles of unfinished filters, and you don't have the ability to create folders for any kind of filter organization...... Steve
| Posted: October 7, 2007 1:58 pm | ||||||||||
crazycase
Posts: 2 |
Hi again.
I want to start off and apologize that I said that filters named that way are low quality. I was wrong there. I've realized that quality is totally dependent on how useful a filter is. Since people have entirely different uses for FF, there's no way to say one is better than another. I will fess up however and admit it: I was totally trollish in my wording, a part of me wanted to see what kind of response I'd get. I did, however, want to see what reasons people had, beyond glory. I posted anonymously for two reasons, first- I didn't want to be banned (Didn't want to risk it just in case), second because my one laughable attempt at a filter would be brought out for comparison, a point which does nothing but waste time. I'm not a filter artist and probably won't ever be. I not even able to make what I would have earlier considered a low quality filter. That doesn't mean I can't have an opinion about the filters here: That's like telling someone they can only say they didn't like a movie if they could do a better job. I want to make it clear that I'm not one of the "regulars" here, I'm mostly a silent lurker. I don't want to cause any sort of divide between you guys, you're a friendly community (almost sickeningly so About the naming issue it self, you guys brought up some good reasons why it's advantageous to name things that way. I didn't have to be so volatile in my first post, but I did get some valid reasons regarding the naming, so I guess that's that. Stay cool guys. |
| Posted: October 8, 2007 12:07 am | ||||||||||
Well you still should have written under your own name. If you have an opinion with valid arguments and stay polite you should be able to speak your mind. When you post stuff like this anonymously people are apt to take it the wrong way.
| Posted: October 8, 2007 4:46 am | ||||||||||
Sjeiti is right it is a shame you took this approach, as you would have been welcomed into the forum and you easily could have started a valid debate about naming without being ridiculed over your work or speaking your mind. Ahimsa is the one you upset unfairly and that you should be ashamed of. That said credit to you for your second post.
| Posted: October 8, 2007 8:29 am | ||||||||||
thanks for that last, entRo
| Posted: October 8, 2007 1:53 pm | ||||||||||
Looks like I pretty much called this one, eh???
I dont't have a problem with that.....I want critiques and feedback to hear how I can improve my filters.....and like everyone else, it also gives me a good feeling to know when people like my filters and find them useful.....if that is the "glory" you are talking about, then I'm guilty as charged
.....using the forum as your own little science experiment to get informatoin by being intentionally offensive to authors here.....with deliberate disregard and inconsideration of knowing that this is a friendly forum and how it would be negetively affected by it.....
.....so I personally find this disingenuous at best.....
I may be wrong, but reading between the lines, I get the feeling that you would like to be a part of this.....but maybe feel that this forum is either too "clicky" or fear that your filtermaking skills might not be good enough. If this is the case, I would say just come on in and try your hand at it.....you certainly seem intelligent and clever enough to channel it towards making some useful filters.....and taste some of the "glory" for yourself Steve
| Posted: October 8, 2007 2:14 pm | ||||||||||
| Posted: October 8, 2007 2:51 pm | ||||||||||
Hey, I would encourage it Steve
| Posted: October 8, 2007 3:33 pm | ||||||||||
Always found the idea of putting my name in front of my filters a bit vulgar, but hey, that might just be me...
![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: October 8, 2007 3:41 pm | ||||||||||
Yeah, well I've always found the idea of putting and cute offbeat names on my filters a bit vulgar.....so we're even
LMAO..... J/K..... I actually do like alot of the names you come up with Steve
| Posted: October 8, 2007 3:58 pm | ||||||||||
Hey, me loves me my !
| Posted: October 9, 2007 6:35 am | ||||||||||
well, with a name like 'crap a dilla', i can see why you might not want to put it in your filter name. 'here's crap-glass-1, guys'. lol.
| Posted: October 9, 2007 8:27 am | ||||||||||
Yeah. And what's a "dilla" anyway?
| Posted: October 9, 2007 8:30 am | ||||||||||
Dilla, weren't you thinking of changing "Crappadilla" over to your real name???
| Posted: October 9, 2007 1:23 pm | ||||||||||
his real name is Dill Crappa
| Posted: October 9, 2007 2:16 pm | ||||||||||
Crappanski Dillanski???
Seriously, given the quality of filters, I would think that Dilla would want to use his real name.....by connectiing the dots on all his work through searching on the web.....kinda like pulling the whole resume together under one household name Steve
| Posted: October 9, 2007 2:22 pm | ||||||||||
| jffe |
Maybe he has a "serious" day jawb, and wouldn't want the CIA or whatever to know his hobby is making some of the wildest photoshop filters known to man ha-ha
| Posted: October 9, 2007 3:08 pm | ||||||||||
That makes perfect sense.....a cover for his world.....errr.....filter domination plot
| Posted: October 9, 2007 3:19 pm | ||||||||||
| Posted: October 9, 2007 3:30 pm | ||||||||||
Crapadilla IS my real name. It's a traditional krakosian name. --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: October 11, 2007 4:02 am | ||||||||||
*mumbles to himself*
Hah, that finally convinced them! Excellent. Now back to implementing 'The Plan'... --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: October 21, 2007 6:12 am | ||||||||||
28 unregistered users.
