Mr.Fale
Want to greatly increrase filter size for large poster how do I do it??
ssamm
Filters: 21
The size is determined by the size of the imported/inputted image.
E.g. If you use FF as a plugin with Photoshop, the size will be determined by the image you are working on.
Or if you use FF as a stand alone program, the image selected from the "File>Open Image..." menu determines the size. Or if you use "File>New Image..." it will give you a dialogue box where you can set the size.
19 unregistered users.
