rilos
rilos
Filters: 9
Hi everybody,
I just installed and tried FF, quite impressive but rather slow.
I wonder if there is any restriction in der rendering size (image output) because I cant choose bigger than 600x600 pixels ?
Is this a limitation to the beta ?
I read something about very big renders (30000 x 30000 or more) ?
Is there any tutorial yet ?
I only found empty space in the tuts section ?
Thanks a lot!
Best regards,
Rilos
regards, rilos
Rilos, have you tried the speed fix?
http://www.filterforge.com/forum/read...=5&TID=116
I suppose you're working in a atand-alone version, right? If so, create a 30000x30000 image in Photoshop, save it, then open it in Filter Forge via File > Open.
rilos wrote:
Is there any tutorial yet ? I only found empty space in the tuts section ?
When we release the full version, it will include a help file. No tutorials at the moment, but I'm sure they will appear.
rilos
rilos
Filters: 9
Thanks, Vladimir for your quick answer!
Yes, I've just made the speed fix, and it works recognizable faster !
Yes, I used the standalone version for testing. There the size is limited to 600x600 pixels. Will try the workaround. Just tried to produce larger tileable textures.
The wood-texture filter is really nice, with lots of variations.
The naming of the parameters is a little non-intuitive, but it works fine.
Will try to produce some wood-specific filters smile:-)
best regards,
rilos
regards, rilos
Yes, that's the common problem with user-submitted filters.
rilos
rilos
Filters: 9
It could also be an improvement to let the user choose the rendering size independently of any loaded image.
The standard restriction to 600 pixels could be the default value - fine - but the user should be able to set it to any possible value (without loading a picture of that size). smile:)
regards, rilos
"File > New Image..." menu command is coming in the next update:
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
23 unregistered users.
