Lucato
FF addicted
Does anybody know if is It possible to order/organize the sequence of the sliders in settings tab?
I was creating a filter and just renamed one slider and after I save the filter, the sequence was changed. I rename back how it was and It didn't come back to previous sequence. Pretty weird.
The software currently does not have a manual method to set the order.
I do have a workaround which is give each control a name starting with a different letter such as "a) Size | b) Complexity". It doesn't always work right but its better then nothing. See my uberLENS 2 filter for an example.
lucato,
we were told by vladimir in a different thread that the controls are arranged alphbetically. this seems to be the case, at least in part. i think there may be exceptions, however. mode switches, for example, dont seem to follow this rule.
craig
Lucato, the "Order of Controls" feature is already planned. Here's how it will look:
Nice... hopefully we'll be able to add dividers as well.
Lucato
FF addicted
@ Vladmir
Nice rough Vlad. It will be grat! Thanks. smile:) Hey Vlad, just adding some other suggestion of "Order of Controls". Maybe instead of using an pop-up window we would just drag and drop the sliders in the own settings tab. Getting the uberzev suggestion, maybe keep one divider on the top, so if we drag It copies the divider and we drop wherever we want. Anyway the pop-up will be amazing.
@ Uberzev
Hey uber, thanks for the tips. I gave It a try, but as you've said "It doesn't always work right". That was my case. smile;)
@ Craig
Thanks for sharing the info.
Cheers,
Lucato.
Yes, the initial idea was to make the order of controls "draggable", but we had to abandon it because it was relatively low-priority and we had more important stuff to do at that time.
Igor Lorents
Filter Forge, Inc.
Thanks God, not all of our prototypes look like that. smile:)
now see, that's not fair. i want the skin that looks like that when you guys get around to custom skins smile;)
craig
Lucato
FF addicted
Hey Igor, that was funny. Welcome to the forum.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
20 unregistered users.
