Just saw filters posted today..Had to check a couple of times to make sure its Saturday...Is this going to start being a new thing or just to catch up from the beginning of the week? smile:hammer:
Wow, that is about a first eh. Not sure why they aren't posted automatically/instantly really. Has anyone ever had a filter rejected ?
Yes I've had one reject for taking to long to render which was fair enough, regigged and was excepted........... Carl smile:)
It a lonely place being the only person to have a filter reject smile:( what about you 2 ............... Carl smile:)
Carl wrote:
It a lonely place being the only person to have a filter reject Sad what about you 2 ............... Carl
Yep I am there with you..I had one rejected before. It was a looong time ago it seems
thou...I think it was my second one..It was to simple and could easily be reproduced in other apps..
Huh, I haven't had one rejected. I should have had several rejected ha-ha, but haven't. Do they send you an email explaining why it was rejected ?
Yes they do and I emailed them to find out what was too long - Carl smile:)
Carl, Vlad posted this which might help.....
1. SLOWEST: Image-based components (Blur, Motion Blur, Sharpen and High Pass) with any slow component (like Worley-based noise) as a source.
2. SLOW: Worley-based noises (any Noise except Perlin, which is very fast).
3. SLOW: Image-based components (see above) in general, because they need to prepare a source bitmap before rendering themselves.
4. CAN BE SLOW: Refraction, especially with a slow component as a source. Refraction takes 3 samples of the source input.
5. CAN BE SLOW: Any Noise (or any component based on Noise such as Noise Gradient, Noise Distortion or Noise Curve) with high Detail and Roughness (they are interdependent) especially with a custom curve as a profile.
6. CAN BE SLOW: Any Noise with a custom curve as a profile -- the curve is sampled once for each noise octave (for Details = 10 you have 10 samples of the curve per one noise sample).
5. CAN BE SLOW IN CERTAIN CASES: Any component that generates edges for anti-aliasing (Patterns, Worley noises, some of the adjustments). But since anti-aliasing is done in a separate pass, that shouldn't impact speed too much.
6. FAST: Patterns, Channels, Adjustments, Gradients (except for Noise gradient).
7. ULTRA-FAST: Externals (Image and Selection), Checker, Switch, Blend, Offset.
Good tip Steve smile:) I have sped up alot of my older filters and my newer ones are alot better - the one rejected took I think about 15 minutes to render [ I hear the words shock horror smile:D hey every one has to start somewhere smile:) ] most take about 8 sec to 2 min the 2 minute ones seem unaviodable - you've probably never waited long enough to see those ones smile:D as I know yours are speedies............. Carl smile:)
PS helpful list thanks
You are more than welcome!!! smile:)
Yeah, the deeper I get into this, the more I subscribe to Uber's efficiency approach.....making my filters as simple, fast, and efficient as possible to achieve the desired effects..... smile:)
Being a little slower can't be all bad as quite alot of editors picks are surprisingly slow smile:D ............ I do agree fast renders are better, that irrating waiting can drive you mad........... Carl smile:)
So now we know why there were new filters listed Saturday eh, none since then, and it's almost Wednesday.
