Cassel
Cassel
I have been using Filter Forge with PaintShop Pro for many years. Typically, when I generate an effect with a filter, the next time I load FF (in the same session), it would immediately show the last filter used. That is convenient to generate different variations of the same filter.
Last week, I used it with Affinity, and I find that it always reverts to the same "default" filter so I lose the last one I had, and the settings I had.
So this is a different behavior for FF when used through two different host programs. Is it due to FF behaving differently, or are the programs handling FF differently?
After you choose the settings that you want for the filter and before applying it to the image go to the presets and click the little drop down menu and "add preset".
This will keep the settings and then you can choose that next time you use that filter. When you change the settings you can update that preset or add another one...
Cassel
Cassel
I understand that I can save a preset. But even if I do, the second (or third) time I load FF in the same session, I still have to navigate or search for the last filter I used. This is quite inconvenient and very different from one program to the other.
Seems to work in the windows version. It goes back to the same filter but one still has to choose the preset. FF defaults to the first preset in that filter...
Cassel
Cassel
That is not my experience at all. Using Affinity, it always reverts to a filter that was NOT the last one, while with PSP, it reloads the same filter and even the same settings, even if I had changed them in the last use.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
37 unregistered users.
