popshot1190
Posts: 1 |
Hey, I cant seem to get a single Normal map or any other type... saving the render and its basically blank...just a example of a map...I am new to FF. any help would be greatly appreciates.
POPSHOT |
| Posted: June 23, 2026 1:06 pm | ||
Guide on how to use texture maps PBR export with Filter Forge for 3D
Here is a guide I had before and rebuilt it now for any FF user that may want to know about this topic and be useful and helpful QUESTIONS TO HELP YOU MORE What filter are you using to try to get a normal map? What version of filter forge you are using? Can you explain and tell step by step what you are doing to get them? Wh ere do you want to use these normal maps? I mean in what other 3D software? Because there are different ways to import and create a 3D PBR texture materials depending op what software you may want to use Depending on what software you may be using there could be automatic ways to build the PBR texture material using the exported and rendered maps from filter forge |
| Posted: June 24, 2026 4:17 pm | ||
