RobertPeinkofer
Posts: 3 |
Hi,
I just bought Filter Forge 13 Pro tonight to use as a filter plugin with Photoshop 2024. After I installed FF13 I moved the 64bit icon into the plugin folder of Photoshop. Under the filter tab, FF13 shows up, but I get an error message when I try to use it..."can not recognize Filter Forge 13 command" or something like that. How do I install FF13 so I can use it as a filter? Thank you!! |
| Posted: December 29, 2023 10:44 pm | ||
Answer here
| Posted: December 30, 2023 2:00 am | ||
RobertPeinkofer
Posts: 3 |
So, I guess I solved the Photoshop problem I was having by doing nothing. Also, FF13 works fine with the (beta) version of PS 2025!! I opened PS 2025 and found that FF13 was in the filter list. I loaded an image, clicked on FF13, and it popped up no problems! Now I just need to turn off the seamless tile in some of the "Texture" presets I want to use for my borders / enclosue artwork so I can get one smooth pass over the entire image without it giving me a half image, half black or purple.
| Posted: January 4, 2024 10:50 am | ||
You can turn off the seamless tiling by going to the filters settings and turning that off. A couple of things to keep in mind. Once you turn off that setting save that as a new preset otherwise that will be the default for that certain preset. Depending on the filter and how it was created it may be using the components that are for square textures only so having a non-square texture will not work or not look very good.
| Posted: January 4, 2024 1:45 pm | ||
RobertPeinkofer
Posts: 3 |
I've been noodling/doodling for a few hours this afternoon, and the "turn off seamless" works GREAT!!! I was really bummed in the beginning when the program wasn't working, and I couldn't do a lot of things I needed to do in the standalone. Now...this is probably the best filter plug I have...(also own Flaming Pear stuff, and Boris FX Optics which are all very good as well)!
Glad I finally figured it... |
| Posted: January 4, 2024 4:54 pm | ||
Glad you got it working.
| Posted: January 4, 2024 11:01 pm | ||
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
21 unregistered users.
