gunsan
digital artist
I just want to say that FF works wonderfully together with PaintShopPro 7,04.
I copied the FF folder in Photoshop and placed it in PSP plugin folder.
PSP 7,04 is my "working horse" I use Photoshop just sometimes.
Just wanted to tell you this, because there is no option for installing other than in Photoshop.
actually, at least on psp 9, 10, and 11, they are all recognized by the installer. havent currently got 7 installed, so cant speak to that one.
onyXMaster
Filter Forge, Inc.
The reason we did not include the older Paint Shop Pro versions is that we did not test Filter Forge for compatibility and hence do not provide support for them. So it potentially may work with any Photoshop-compatible host out there, we just did not do the testing. By the way, this list is not very strict, if users need support for some not-so-conforming hosts, we usually look into it (for example, Ulead PhotoImpact made it to the supported hosts list exactly this way, by users' requests).
gunsan
digital artist
I just wrote this to share if somebody still, like me, is working in PSP 7.04.
I did not mean to critisize in any way, just give a tip smile:)
infiniview
digital artist
FF has worked so well for me as a stand alone program that I had not even noticed
that my PSP 8 had picked it up until later.
Now I also have it hooked up with CS 2, I had 5.5 before and I had not tried using it with that one, does your comment mean it would Onyx? smile:)
generally speaking, if your editor can use other .8bf plugins, then it can use FF.
