Bookwormious
I can use Filter Forge 12 as a stand alone program. But despite it promising at the installation to be a plugin in the new Photoshop Beta it does not work inside the 'shop. It's on the filter list, but does not work.
Any help will be appreciated smile:)
Windows or OSx?. If its windows I have a manual install for photoshop video. Photoshop Filter Forge manual install
Bookwormious
Thanks a bundle for that smile:) And yes, Windows. Sorry for specifying that smile:D
The video showed the former Photoshop, and Filter Forge 11, though. But I will try it out just the same a bit later today, and see of it works for the newer stuff, too smile:D
Bookwormious
It DID work smile:!:
Thank you ever so very much smile:)
Cool glad it worked for you. FF and photoshop usually work the same file structure wise for many versions. When photoshop changes the file structure for plugins then I would need to make another video. FF has remained the same for years as well. Although you will reach a version that just does not work.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
20 unregistered users.
