Yan 85
I'm looking for a filter that make cuts and mix (collage) the image looks like on attachment.
I forgot make back up the filters, and after reinstalling FF i lost this filter.
Yan 85
Example of the grid on which the filter make cuts
As I see on the example it seems that it takes the original image and then it breaks in irregular polygonal shapes and jumble them
Sorry I do not know what filter may it be, but maybe I can help you with a filter that I made that is not in the FF library but can be found in You can Jumble Noises also using this instead of only tiles
Is really very convenient, safe and spend a little time to make a backup of the filters you may have downloaded to avoid having problems and loose your filter collection and having to download all again or the filters you have downloaded from the forum (not in FF library) or the ones you have made
Do you make a backup of any filter you are creating to be safe?
If you are using FF from version 8 onward there is already built in an automatic backup that is very easy to use and fast
Backup and Restore Your Filters and Settings
I found 3 filters... probably not the one you're looking for but maybe useful:
Jumble
Jumbler
Grid Painter
STEPH08
Jumble/Jumbler:
I am always surprised at the huge differences in optimization/calculation time of filters that produce a similar effect.
Some filters are barely usable on 24MP+ images even with powerful CPUs and lots of memory; 'Painting' filters are the worst in terms of processing time and memory usage.
Grid Painter:
Good filter, it will be useful for me.
Where did you get the filter from? Downloaded fr om the FF library or from the forum pages?
If it is a filter from the library, I would also like to know and would be interested to know which is it, because I have not seen any filter that is able to make this and this is why I asked in the thread I created.
Looking at the example, it looks very much like the filter I have shown on the answer I gave above wh ere the filter is available in that thread
Although your filters are very good and well done and I like them much, I think that they do not do what is shown in the example on the first post
Yan 85
Yeah, it's the same filter! Thank you very much! I spent lot of time in FF library search. But i forgot that the filter not from library)
Also, thanks for backup links. It will be useful for me.
Yan 85
Jumble
Jumbler
Grid Painter
Thanks for the answer! I saw these filters when I was in searching.
They are similar but not what I wanted.
Yan 85
worley jumble with controls outline edges.ffxm – realy good filter. You need add to FF library.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
26 unregistered users.
