CaliKat
It is not just Filter Forge 11. None of the Filter Forge versions show PSP 2023 as an option to download as a plugin to. All other versions of Paint Shop Pro show up on the install screen. There is no way to manually point the install to the PSP 2023 folder. Is this a known problem? PSP 2023 is a 64 bit version so installing there will not be a problem if FF can find the program. Is there a way I can help it do that? I am using windows 10.
patara
I don't have PSP 2023 but you should be able to point PSP to the Plugin via File/Preferences/File Locations/Plugins
FF 12 does support PSP 2023, while version before 12 don't. You can copy-paste images between FF and any graphic editor if you don't want to upgrade to v12.
CaliKat
Thank you Patara. I did try pointing my program to the file location but it did not work.
Thank you GMM. Coincidentally, I just recieved my FF 12 serial in the mail today so will be installing that version soon and hopefully, there will be joy.
CaliKat
I have downloaded and installed FF 12 and it works perfectly in PSP 2023 as a plugin and also in the older versions of PaintShop Pro that I use (unlike FF 11 which I had to use as a stand alone). Filter Forge is such a great filter and I am happy to have it installed and working well in my new PSP 2023.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
20 unregistered users.
