cabaer
Has anybody actually worked with the new feature of the Studio Edition? Can you post your work? I still don't quite understand what it actually does. There seems to be conflicting information. Does it create animation or can it be used to apply filters to an existing video?
In some simple terms you can do both. First the animation. Lets take a face of a clock that you create in filter forge as a filter. You can take that filter and add
some controls to animate the hands on the clock. Now create a new project and import that filter into a new artboard. You can now render out the frames of that filter
as a video.
Now comes the video. Again Create a new project and artboard and you can open a video and apply a filter to that video by importing a filter into the artboard.
I have a video tutorial that I created with very basic animated text and how to create the effect in Filter Forge. There is sound on the animated text but not with the tutorial part. Got to find time to finish it.
Animated Text Tutorial
Here is another example video of a public domain clip with some different filter effects. The first clip is the original.....
External Video Added Effects
One thing to note is when using an external video not all filters will process that nor load that video. When choosing the filters where
you need to load an image through the settings tab you will need to edit the filter and change that color control to the Image component.
You then can load the video with that filter....
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
22 unregistered users.
