Allele Graphics
Posts: 8 |
I purchased the Professional version of FF 11.
I am running Windows 11 and Photoshop CC (2022) I downloaded FF 11 and cannot get it to install at all... would appreciate ANY help I can get in getting this to work. Thank you in advance for any help! Stacey |
| Posted: October 17, 2022 12:44 pm | ||||||
Posts: 3507 |
Stacey, welcome to the forums!
To install FF, please download and run the installation wizard from the Download page. |
| Posted: October 19, 2022 5:15 am | ||||||
Allele Graphics
Posts: 8 |
Hello GMM Moderator...
I have downloaded, installed and registered my copy, but I STILL can't get it to work within Photoshop CC 2022... I am not sure what I am supposed to be doing to get it to work properly, but obviously I am not doing it right... I really want to use FF and have been a loyal customer in the past... but if it will not work with Photoshop CC 2022 then I want a refund... can you help at all? Thanks in advance. Stacey |
| Posted: October 19, 2022 1:24 pm | ||||||
| Posted: October 19, 2022 3:03 pm | ||||||
I also have a video of how to install the plug-in manually. This is for windows10 and Photoshop 2020. The version of FF is 8 but also applies to FF11. You do not need to edit the config file as in the video. FF Manual Install
Follow the video up to the point of where I place the files needed into the photoshop plug-ins folder and you should be good... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 19, 2022 3:10 pm | ||||||
Posts: 3507 |
Stacey, first you say "cannot get it to install at all", then "I have downloaded, installed and registered my copy". So, does FF work for you or not? You need to make the standalone version works fine before troubleshooting the plugin.
Also, CFandM is correct: you need to enable the plugin checkbox in the installation wizard. |
| Posted: October 20, 2022 7:59 am | ||||||
Allele Graphics
Posts: 8 |
Hi again GMM Moderator,
I guess I wasn't very clear on that... I DID get it downloaded, installed and registered... and the Standalone version opens and works, what I meant is that I am not able to get it to install or work as a plugin within Photoshop, which is where I am used to using FF. I actually have never used the Standalone version, I have always used it as the plugin for Photoshop... and I DID enable the plugin checkbox on the installation wizard. I am wondering if there is a compatibility problem with Windows 11 or with Photoshop 2022 (or any updates for either of these). I REALLY love FF and want to use it... but honestly, I really just want it as the plugin, does that make sense? I love CFandM's comment "Stupid things happen to computers for stupid reasons at stupid times!", but sometimes it's just the stupid operator (me in this instance!) I REALLY appreciate all of your help! And again, forgive my mistake in how I described my issue in the first place. Thanks... Stacey |
| Posted: October 20, 2022 2:00 pm | ||||||
Mr Mud Stain
Posts: 8 |
This may not be relevant, but Photoshop has recently been updated to the new 2023 version, which, from past experience, does not support previous versions of Filter Forge. In fact, I'm fuming because today, Adobe overrode my cloud preferences to NOT update Photoshop, for this very reason. Now I can't use FF until version 12 is released.
| Posted: October 20, 2022 8:41 pm | ||||||
Check the link to the video I posted above.. Assuming you are using windows. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 20, 2022 8:59 pm | ||||||
| Posted: October 20, 2022 9:02 pm | ||||||
Posts: 3507 |
Does Filter Forge 11 show up on the Filter list in Photoshop?
That's not a compatibility problem, it's just the way the cookie crumbles. FF11 has full support for PS 2022 but not for any later PS version. |
| Posted: October 21, 2022 6:10 am | ||||||
Posts: 3507 |
Mr Mud Stain, please try the beta version of FF12 and check if it works fine with CC2023. |
| Posted: October 21, 2022 6:11 am | ||||||
Allele Graphics
Posts: 8 |
Good morning GMM Moderator...
to answer your question "Does Filter Forge 11 show up on the Filter list in Photoshop?"... no it does not, that is what I am looking for!! Thanks! |
| Posted: October 21, 2022 7:18 am | ||||||
Posts: 3507 |
Looks like you'll have to install the plugin manually. Please check these two locations: Applications/Adobe Photoshop 2022/Plug-Ins/Filters/ Library/Application Support/Adobe/Plug-Ins/CC/ and remove all Filter Forge 11-related files from there. Make sure to terminate Photoshop (not just collapse into Dock). Next, open the Applications > Filter Forge 11 folder. In another Finder window, open Library > Application Support > Adobe > Plug-Ins > CC. Next, create an alias for the “Filter Forge 11 universal.plugin” file in the /Library/Application Support/Adobe/Plug-Ins/CC/ folder (Alt+Command+drag and drop the file from the first window to the second one). Finally, run Photoshop 2022 and check if Filter Forge appears on the Filter list. |
| Posted: October 21, 2022 8:02 am | ||||||
Allele Graphics
Posts: 8 |
good morning again GMM Moderator... I have been doing the manual install and I got to
"In another Finder window, open Library > Application Support > Adobe > Plug-Ins > CC" I am totally dumbfounded because I can't find "Library > Application Support > Adobe > Plug-Ins > CC" anywhere on my computer... I have "Programs > Adobe > Plug-ins > Filters" open... and I did this... "Alt+Command+drag and drop the file from the first window to the second one" - when I open Photoshop it has an error code "One or more plug-ins are currently not available on your system. For details, see Help > System Info." when I hit ok, and start a new file... then when I go to Plugins drop down it is NOT listed, but when I go to Filters drop down it shows up there... when I click on it has an error code: "Could not complete the Filter Forge 11 command because of a problem with the filter module interface." So SORRY to be such a pest.... |
| Posted: October 21, 2022 10:58 am | ||||||
Allele Graphics
Posts: 8 |
One more thing... when I did check the "Help > System Info" this is what I see (hope it helps):
Adobe Photoshop Version: 23.5.1 20220907.r.724 5600b96 x64 Number of Launches: 24 Operating System: Windows 11 64-bit Version: 11 or greater 10.0.22621.674 System architecture: Intel CPU Family:6, Model:12, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, AVX-512, HyperThreading Physical processor count: 4 Logical processor count: 8 Processor speed: 3418 MHz Built-in memory: 32514 MB Free memory: 20842 MB Memory available to Photoshop: 24987 MB Memory used by Photoshop: 70 % Crash Handler: Adobe DCX Version: 6.7.1 SAM SDK Version: 2.0.0-main.1351 ACP.local Status: - SDK Version: 2.7.1.1 - Core Sync Status: Reachable and compatible - Core Sync Running: 5.17.9.1 - Min Core Sync Required: 4.3.66.28 Live Edit Client SDK Version: 3.90.3 Content Credentials is disabled Content Credential Helper Version: Not Available Manta Canvas: Enabled. Alias Layers: Disabled. Modifier Palette: Enabled. Highbeam: Enabled. Image tile size: 1024K Image cache levels: 4 Font Preview: Medium HarfBuzz Version: 2.8.1 TextEngine: Unified Text Engine ======= GPU Native API stable: True OpenGL API stable: True OpenCL API stable: True GPUDeny: 0 GPUForce: 0 useGPU: 1 useOpenCL: 1 isGPUCapable: 1 GPUName: NVIDIA GeForce RTX 3050 Laptop GPU GPUVendor: NVIDIA IsNativeGPUCapable: 1 IsOpenGLGPUCapable: 1 IsOpenCLGPUCapable: 1 HasSufficientRAM: 1 GPU accessible RAM: 4,186 MB Required GPU accessible RAM: 1,500 MB UseGraphicsProcessorChecked: 1 UseOpenCLChecked: 1 Windows remote desktop: 0 Display: 1 Display Bounds: top=0, left=0, bottom=2399.99, right=3839.99 ------- Sniffer output [0 ms] Launch GPUSnifferThread [0 ms] Start RunAllAPIs [0 ms] "C:\Program Files\Adobe\Adobe Photoshop 2022\sniffer.exe" -baseTimeMS=8642390 -comment=Photoshop Version: Adobe Photoshop 23.5.1 20220907.r.724 5600b96 x64 [1607 ms] Start GetSnifferResult [2995 ms] Start sniffer 2022-10-21 10:53:30 # Photoshop Version: Adobe Photoshop 23.5.1 20220907.r.724 5600b96 x64 C:\Program Files\Adobe\Adobe Photoshop 2022\sniffer.exe -baseTimeMS=8642390 -comment=Photoshop Version: Adobe Photoshop 23.5.1 20220907.r.724 5600b96 x64 {32 ms} Start platform native # displays: 1 Display 0 Display: \\.\DISPLAY1 Main: TRUE Built in: FALSE Stereo: FALSE Bounds: (0, 0) -> (1,707, 1,067) Dimensions: (1,707 1,067) Physical size: (0 0) Pixel size: (0 0) Dynamic range: (0 1) Potential dynamic range: (0 1) Reference dynamic range: (0 0) Attached Device: (DeviceID name=NVIDIA GeForce RTX 3050 Laptop GPU index=0 preferred=1) # devices: 2 Device 0 Name: NVIDIA GeForce RTX 3050 Laptop GPU Preferred: TRUE Power Envelope: UNKNOWN Attachment: UNKNOWN # attached displays: 1 \\.\DISPLAY1 GPU accessible RAM: 4,186 MB VRAM: 4,186 MB Dedicated System RAM: 0 MB Shared System RAM: 17,046 MB API version: 12.0 (12.0) Device version: 12.0 (12.0) Vendor name: NVIDIA Driver date: 2022-05-05 000000.000000-000 Driver age: 5 months Driver version: 30.0.15.1278 Supports UMA: UNSUPPORTED D3D-ID: 9634 Device 1 Name: Intel® Iris® Xe Graphics Preferred: FALSE Power Envelope: UNKNOWN Attachment: UNKNOWN # attached displays: 0 GPU accessible RAM: 17,180 MB VRAM: 134 MB Dedicated System RAM: 0 MB Shared System RAM: 17,046 MB API version: 12.0 (12.0) Device version: 12.0 (12.0) Vendor name: INTEL Driver date: 2022-01-20 000000.000000-000 Driver age: 9 months Driver version: 30.0.101.1338 Supports UMA: SUPPORTED D3D-ID: 39497 End platform native {250 ms} {250 ms} Start platform OpenGL # displays: 1 Display 0 Display: \\.\DISPLAY1 Main: TRUE Built in: FALSE Stereo: FALSE Bounds: (0, 0) -> (1,707, 1,067) Dimensions: (1,707 1,067) Physical size: (0 0) Pixel size: (0 0) Dynamic range: (0 1) Potential dynamic range: (0 1) Reference dynamic range: (0 0) Attached Device: (DeviceID name=NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2 index=0 preferred=1) # devices: 1 Device 0 Name: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2 Preferred: TRUE Power Envelope: INTEGRATED Attachment: UNKNOWN # attached displays: 1 \\.\DISPLAY1 GPU accessible RAM: 4,186 MB VRAM: 4,186 MB Dedicated System RAM: 0 MB Shared System RAM: 17,046 MB API version: 2.1 (2.1.2 NVIDIA 512.78) Device version: 2.1 (2.1.2 NVIDIA 512.78) Vendor name: NVIDIA Driver date: 2022-05-05 000000.000000-000 Driver age: 5 months Driver version: 30.0.15.1278 GLSL version: 1.20 (1.20 NVIDIA via Cg compiler) End platform OpenGL {334 ms} {334 ms} Start platform OpenCL # displays: 0 # devices: 5 Device 0 Name: NVIDIA GeForce RTX 3050 Laptop GPU Preferred: FALSE Power Envelope: DISCRETE Attachment: UNKNOWN # attached displays: 0 GPU accessible RAM: 4,294 MB VRAM: 4,294 MB Dedicated System RAM: 0 MB Shared System RAM: 0 MB API version: 3.0 (OpenCL 3.0 CUDA) Device version: 3.0 (OpenCL 3.0 CUDA) Vendor name: NVIDIA Driver date: UNKNOWN Driver age: UNKNOWN Driver version: UNKNOWN Bandwidth: 160 GB / s Compute score: 1,968.94 Device name string: NVIDIA GeForce RTX 3050 Laptop GPU Device vendor string: NVIDIA Corporation Platform name string: NVIDIA CUDA Platform vendor string: NVIDIA Corporation Device 1 Name: Intel® Iris® Xe Graphics Preferred: FALSE Power Envelope: INTEGRATED Attachment: UNKNOWN # attached displays: 0 GPU accessible RAM: 13,637 MB VRAM: 13,637 MB Dedicated System RAM: 0 MB Shared System RAM: 0 MB API version: 3.0 (OpenCL 3.0 ) Device version: 3.0 (OpenCL 3.0 NEO ) Vendor name: INTEL Driver date: UNKNOWN Driver age: UNKNOWN Driver version: UNKNOWN Bandwidth: 36 GB / s Compute score: 875.927 Device name string: Intel® Iris® Xe Graphics Device vendor string: Intel® Corporation Platform name string: Intel® OpenCL HD Graphics Platform vendor string: Intel® Corporation Device 2 Name: NVIDIA GeForce RTX 3050 Laptop GPU Preferred: FALSE Power Envelope: DISCRETE Attachment: UNKNOWN # attached displays: 0 GPU accessible RAM: 4,186 MB VRAM: 4,186 MB Dedicated System RAM: 0 MB Shared System RAM: 0 MB API version: 1.2 (OpenCL 1.2 D3D12 Implementation) Device version: 1.2 (OpenCL 1.2 D3D12 Implementation) Vendor name: MICROSOFT Driver date: UNKNOWN Driver age: UNKNOWN Driver version: UNKNOWN Bandwidth: 50,397 GB / s Compute score: 1.96609e+06 Device name string: NVIDIA GeForce RTX 3050 Laptop GPU Device vendor string: Microsoft Platform name string: OpenCLOn12 Platform vendor string: Microsoft Device 3 Name: Microsoft Basic Render Driver Preferred: FALSE Power Envelope: INTEGRATED Attachment: UNKNOWN # attached displays: 0 GPU accessible RAM: 17,046 MB VRAM: 17,046 MB Dedicated System RAM: 0 MB Shared System RAM: 0 MB API version: 1.2 (OpenCL 1.2 D3D12 Implementation) Device version: 1.2 (OpenCL 1.2 D3D12 Implementation) Vendor name: MICROSOFT Driver date: UNKNOWN Driver age: UNKNOWN Driver version: UNKNOWN Bandwidth: 4,724 GB / s Compute score: 8,707.36 Device name string: Microsoft Basic Render Driver Device vendor string: Microsoft Platform name string: OpenCLOn12 Platform vendor string: Microsoft Device 4 Name: Intel® Iris® Xe Graphics Preferred: TRUE Power Envelope: INTEGRATED Attachment: UNKNOWN # attached displays: 0 GPU accessible RAM: 17,046 MB VRAM: 17,046 MB Dedicated System RAM: 0 MB Shared System RAM: 0 MB API version: 1.2 (OpenCL 1.2 D3D12 Implementation) Device version: 1.2 (OpenCL 1.2 D3D12 Implementation) Vendor name: MICROSOFT Driver date: UNKNOWN Driver age: UNKNOWN Driver version: UNKNOWN Bandwidth: 16,574 GB / s Compute score: 290,550 Device name string: Intel® Iris® Xe Graphics Device vendor string: Microsoft Platform name string: OpenCLOn12 Platform vendor string: Microsoft End platform OpenCL {2860 ms} Exit code kExitNormal End sniffer 2022-10-21 10:53:33 [kStatusNormal, kExitNormal] [2995 ms] Finish RunAllAPIs [3007 ms] Finish GetSnifferResult ------- Sniffer output ======= GPU License Type: Subscription Serial number: 90970479774261230323 GUIDBucket: Composite Core (enable_composite_core): on Composite Core GPU (comp_core_gpu): off Composite Core Threads (MultithreadedCompositing): on Composite Core UI (comp_core_ui): off Composite Core Feature Prefs (CompCoreFeaturePrefs): off Document Graph (enable_doc_graph): off Application folder: C:\Program Files\Adobe\Adobe Photoshop 2022\ Temporary file path: C:\Users\allel\AppData\Local\Temp\ Photoshop scratch has async I/O enabled Scratch volume(s): Startup, 952.6G, 815.0G free Required Plugins folder: C:\Program Files\Adobe\Adobe Photoshop 2022\Required\Plug-ins\ Primary Plugins folder: C:\Program Files\Adobe\Adobe Photoshop 2022\Plug-ins\ Installed components: A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112 ACE.dll ACE 2022/06/29-00:48:47 79.b8223ff 79.b8223ff AdobeLinguistic.dll Adobe Linguisitc Library 353c9a5 AdobeOwl.dll Adobe Owl 5.5.0 AdobePDFL.dll PDFL 2022/07/05-12:59:37 79.2687e22 79.2687e22 AdobePDFSettings.dll Adobe PDFSettings 1.07 AdobePIP.dll Adobe Product Improvement Program 8.2.0.16 AdobeSVGAGM.dll AdobeSVGAGM 79.cb34c9e 79.cb34c9e AdobeXMP.dll Adobe XMP Core 2022/06/13-17:46:14 79.1b65a79 79.1b65a79 AdobeXMPFiles.dll Adobe XMP Files 2022/06/13-17:46:14 79.1b65a79 79.1b65a79 AdobeXMPScript.dll Adobe XMP Script 2022/06/13-17:46:14 79.1b65a79 79.1b65a79 adobe_caps.dll Adobe CAPS 10,0,0,6 AGM.dll AGM 2022/06/29-00:48:47 79.b8223ff 79.b8223ff AID.dll AID DLL 1.0.0.33 AIDE.dll AIDE 2022/06/29-19:10:01 79.e12ffba 79.e12ffba aifm.dll AIFM 1.0 23.68434 AILib.dll Adobe Illustrator 2022 26.0.0 aiport.dll AIPort 1.0 23.68434 ARE.dll ARE 2022/06/29-00:48:47 79.b8223ff 79.b8223ff AXE8SharedExpat.dll AXE8SharedExpat 2022/02/04-19:11:32 79.97e751e 79.97e751e AXEDOMCore.dll AXEDOMCore 2022/02/04-19:11:32 79.97e751e 79.97e751e BIB.dll BIB 2022/06/29-00:48:47 79.b8223ff 79.b8223ff BIBUtils.dll BIBUtils 2022/06/29-00:48:47 79.b8223ff 79.b8223ff boost_chrono.dll photoshopdva 22.0.0 boost_date_time.dll photoshopdva 22.0.0 boost_filesystem.dll photoshopdva 22.0.0 boost_program_options.dll photoshopdva 22.0.0 boost_regex.dll photoshopdva 22.0.0 boost_system.dll photoshopdva 22.0.0 boost_threads.dll photoshopdva 22.0.0 CoolType.dll CoolType 2022/06/29-00:48:47 79.b8223ff 79.b8223ff CRClient.dll Adobe Crash Reporter Client DLL 4.7.0.0 DirectML.dll DirectML Redistributable Library 1.8.0+211118-1842.1.dml-1.8.278eec2 dnssd.dll Bonjour 3,0,0,2 dvaaccelerate.dll photoshopdva 22.0.0 dvaappsupport.dll photoshopdva 22.0.0 dvaaudiodevice.dll photoshopdva 22.0.0 dvacore.dll photoshopdva 22.0.0 dvacrashhandler.dll Adobe Audition CC 2017 10.0.0 dvamarshal.dll photoshopdva 22.0.0 dvamediatypes.dll photoshopdva 22.0.0 dvametadata.dll photoshopdva 22.0.0 dvametadataapi.dll photoshopdva 22.0.0 dvametadataUI.dll photoshopdva 22.0.0 dvanet.dll photoshopdva 22.0.0 dvaplayer.dll photoshopdva 22.0.0 dvascripting.dll photoshopdva 22.0.0 dvatransport.dll photoshopdva 22.0.0 dvaui.dll photoshopdva 22.0.0 dvavulcansupport.dll photoshopdva 22.0.0 dynamic-torqnative.dll Unified Extensibility Platform uxp-6.2.1-1-cbb9a02 dynamiclink.dll photoshopdva 22.0.0 ExtendScript.dll ExtendScript 2022/01/04-10:07:31 82.3 82.3 filterport.dll FilterPort 1.1 O icucnv69.dll International Components for Unicode Build 13.1.a82691a icudt69.dll International Components for Unicode Build 13.1.a82691a icuin69.dll International Components for Unicode Build 13.1.a82691a icuuc69.dll International Components for Unicode Build 13.1.a82691a igestep30.dll IGES Reader 9.3.0.113 ippcc.dll ippCC. Intel® Integrated Performance Primitives. Color Conversion. 2021.3 (r0x0ee262de) ippcck0.dll ippCC. Intel® Integrated Performance Primitives. Color Conversion. 2021.3 (r0x0ee262de) ippccl9.dll ippCC. Intel® Integrated Performance Primitives. Color Conversion. 2021.3 (r0x0ee262de) ippccy8.dll ippCC. Intel® Integrated Performance Primitives. Color Conversion. 2021.3 (r0x0ee262de) ippcore.dll core. Intel® Integrated Performance Primitives. Core Library. 2021.3 (r0x0ee262de) ippcv.dll ippCV. Intel® Integrated Performance Primitives. Computer Vision. 2021.3 (r0x0ee262de) ippcvk0.dll ippCV. Intel® Integrated Performance Primitives. Computer Vision. 2021.3 (r0x0ee262de) ippcvl9.dll ippCV. Intel® Integrated Performance Primitives. Computer Vision. 2021.3 (r0x0ee262de) ippcvy8.dll ippCV. Intel® Integrated Performance Primitives. Computer Vision. 2021.3 (r0x0ee262de) ippi.dll ippIP. Intel® Integrated Performance Primitives. Image Processing. 2021.3 (r0x0ee262de) ippik0.dll ippIP. Intel® Integrated Performance Primitives. Image Processing. 2021.3 (r0x0ee262de) ippil9.dll ippIP. Intel® Integrated Performance Primitives. Image Processing. 2021.3 (r0x0ee262de) ippiy8.dll ippIP. Intel® Integrated Performance Primitives. Image Processing. 2021.3 (r0x0ee262de) ipps.dll ippSP. Intel® Integrated Performance Primitives. Signal Processing. 2021.3 (r0x0ee262de) ippsk0.dll ippSP. Intel® Integrated Performance Primitives. Signal Processing. 2021.3 (r0x0ee262de) ippsl9.dll ippSP. Intel® Integrated Performance Primitives. Signal Processing. 2021.3 (r0x0ee262de) ippsy8.dll ippSP. Intel® Integrated Performance Primitives. Signal Processing. 2021.3 (r0x0ee262de) ippvm.dll ippVM. Intel® Integrated Performance Primitives. Vector Math. 2021.3 (r0x0ee262de) ippvmk0.dll ippVM. Intel® Integrated Performance Primitives. Vector Math. 2021.3 (r0x0ee262de) ippvml9.dll ippVM. Intel® Integrated Performance Primitives. Vector Math. 2021.3 (r0x0ee262de) ippvmy8.dll ippVM. Intel® Integrated Performance Primitives. Vector Math. 2021.3 (r0x0ee262de) JP2KLib.dll JP2KLib 2022/06/08-13:36:40 79.8753c76 79.8753c76 libifcoremd.dll Intel® Visual Fortran Compiler 10.0 (Update A) libiomp5md.dll Intel® OpenMP* Runtime Library 5.0 libmmd.dll Intel® C/C++/Fortran Compiler Mainline libzip.dll photoshopdva 22.0.0 LogSession.dll LogSession 8.2.0.16 mediacoreif.dll photoshopdva 22.0.0 Microsoft.AI.MachineLearning.dll Microsoft® Windows® Operating System 1.11.20220318.2.b713855 mkl_avx2.1.dll Intel® Math Kernel Library 2021.3 mkl_avx512.1.dll Intel® Math Kernel Library 2021.3 mkl_core.1.dll Intel® Math Kernel Library 2021.3 mkl_def.1.dll Intel® Math Kernel Library 2021.3 mkl_mc3.1.dll Intel® Math Kernel Library 2021.3 mkl_sequential.1.dll Intel® Math Kernel Library 2021.3 mkl_vml_avx2.1.dll Intel® Math Kernel Library 2021.3 mkl_vml_avx512.1.dll Intel® Math Kernel Library 2021.3 mkl_vml_def.1.dll Intel® Math Kernel Library 2021.3 mkl_vml_mc3.1.dll Intel® Math Kernel Library 2021.3 MPS.dll MPS 2022/06/26-19:09:38 79.14a028f 79.14a028f onnxruntime.dll Microsoft® Windows® Operating System 1.11.20220318.2.b713855 opencv_world452.dll OpenCV library 4.5.2 pdfport.dll PDFPort 2020/11/19-11:34:27 79.625377 79.625377 Plugin.dll Adobe Photoshop 2022 23.5 PlugPlugExternalObject.dll Adobe® CEP PlugPlugExternalObject Standard Dll (64 bit) 11.2.0 PlugPlugOwl.dll Adobe® CSXS PlugPlugOwl Standard Dll (64 bit) 11.2.0.100 PSCloud.dll 1.0.0.1 PSRes.dll Adobe Photoshop 2022 23.5 PSViews.dll Adobe Photoshop 2022 23.5 ScCore.dll ScCore 2022/01/04-10:07:31 82.3 82.3 sentry.dll Adobe-Sentry.dll 0.4.17 SVGRE.dll SVGRE 79.2c1e692 79.2c1e692 svml_dispmd.dll Intel® C/C++/Fortran Compiler Mainline TfKernel.dll Kernel Geom 9.3.0.113 TFUGEOM.dll Adobe, UGeom© 9.3.0.113 utest.dll photoshopdva 22.0.0 VulcanControl.dll Vulcan Application Control Library 6.6.0.000 VulcanMessage5.dll Vulcan Message Library 6.6.0.000 WinRTSupport.dll Adobe Photoshop Windows RT Support 1.0.1.0 WRServices.dll WRServices Build 17.4.0.997eb32 17.4.0.997eb32 wu3d.dll U3D Writer 9.3.0.113 Unified Extensibility Platform uxp-6.2.1-1-cbb9a02 UPIC 2.4.1 Required plugins: Accented Edges 23.5 - from the file “Filter Gallery.8bf” Adaptive Wide Angle 23.5 - from the file “Adaptive Wide Angle.8bf” Angled Strokes 23.5 - from the file “Filter Gallery.8bf” Average 23.5 - from the file “Average.8bf” Bas Relief 23.5 - from the file “Filter Gallery.8bf” BMP 23.5 - from the file “Standard MultiPlugin.8bf” Camera Raw 14.5 - from the file “Camera Raw.8bi” Camera Raw Filter 14.5 - from the file “Camera Raw.8bi” Chalk && Charcoal 23.5 - from the file “Filter Gallery.8bf” Charcoal 23.5 - from the file “Filter Gallery.8bf” Chrome 23.5 - from the file “Filter Gallery.8bf” Cineon 23.5 - from the file “Cineon.8bi” Clouds 23.5 - from the file “Clouds.8bf” Color Halftone 23.5 - from the file “Standard MultiPlugin.8bf” Colored Pencil 23.5 - from the file “Filter Gallery.8bf” Conté Crayon 23.5 - from the file “Filter Gallery.8bf” Craquelure 23.5 - from the file “Filter Gallery.8bf” Crop and Straighten Photos 23.5 - from the file “CropPhotosAuto.8li” Crop and Straighten Photos Filter 23.5 - from the file “Standard MultiPlugin.8bf” Crosshatch 23.5 - from the file “Filter Gallery.8bf” Crystallize 23.5 - from the file “Standard MultiPlugin.8bf” Cutout 23.5 - from the file “Filter Gallery.8bf” Dark Strokes 23.5 - from the file “Filter Gallery.8bf” De-Interlace 23.5 - from the file “Standard MultiPlugin.8bf” Dicom 23.5 - from the file “Dicom.8bi” Difference Clouds 23.5 - from the file “Clouds.8bf” Diffuse Glow 23.5 - from the file “Filter Gallery.8bf” Displace 23.5 - from the file “Standard MultiPlugin.8bf” Dry Brush 23.5 - from the file “Filter Gallery.8bf” Entropy 23.5 - from the file “statistics.8ba” Export Color Lookup Tables 23.5 - from the file “Export3DLUT.8be” Extrude 23.5 - from the file “Standard MultiPlugin.8bf” FastCore Routines 23.5 - from the file “FastCore.8bx” Fibers 23.5 - from the file “Standard MultiPlugin.8bf” Film Grain 23.5 - from the file “Filter Gallery.8bf” Filter Gallery 23.5 - from the file “Filter Gallery.8bf” Fresco 23.5 - from the file “Filter Gallery.8bf” Glass 23.5 - from the file “Filter Gallery.8bf” Glowing Edges 23.5 - from the file “Filter Gallery.8bf” Grain 23.5 - from the file “Filter Gallery.8bf” Graphic Pen 23.5 - from the file “Filter Gallery.8bf” Halftone Pattern 23.5 - from the file “Filter Gallery.8bf” Halide Bottlenecks 23.5 - from the file “HalideBottlenecks.8bx” HDRMergeUI 23.5 - from the file “HDRMergeUI.8bf” HSB/HSL 23.5 - from the file “Standard MultiPlugin.8bf” IFF Format 23.5 - from the file “Standard MultiPlugin.8bf” IGES 23.5 - from the file “U3D.8bi” Ink Outlines 23.5 - from the file “Filter Gallery.8bf” JPEG 2000 23.5 - from the file “JPEG2000.8bi” Kurtosis 23.5 - from the file “statistics.8ba” Lens Blur 23.5 - from the file “Lens Blur.8bf” Lens Correction 23.5 - from the file “Lens Correction.8bf” Lens Flare 23.5 - from the file “Standard MultiPlugin.8bf” Liquify 23.5 - from the file “Liquify.8bf” Matlab Operation 23.5 - from the file “ChannelPort.8bf” Maximum 23.5 - from the file “statistics.8ba” Mean 23.5 - from the file “statistics.8ba” Measurement Core 23.5 - from the file “MeasurementCore.8me” Median 23.5 - from the file “statistics.8ba” Mezzotint 23.5 - from the file “Standard MultiPlugin.8bf” Minimum 23.5 - from the file “statistics.8ba” MMXCore Routines 23.5 - from the file “MMXCore.8bx” Mosaic Tiles 23.5 - from the file “Filter Gallery.8bf” Multiprocessor Support 23.5 - from the file “MultiProcessor Support.8bx” Neon Glow 23.5 - from the file “Filter Gallery.8bf” Note Paper 23.5 - from the file “Filter Gallery.8bf” NTSC Colors 23.5 - from the file “NTSC Colors.8bf” Ocean Ripple 23.5 - from the file “Filter Gallery.8bf” OpenEXR 23.5 - from the file “Standard MultiPlugin.8bf” Paint Daubs 23.5 - from the file “Filter Gallery.8bf” Palette Knife 23.5 - from the file “Filter Gallery.8bf” Patchwork 23.5 - from the file “Filter Gallery.8bf” Paths to Illustrator 23.5 - from the file “Standard MultiPlugin.8bf” PCX 23.5 - from the file “PCX.8bi” Photocopy 23.5 - from the file “Filter Gallery.8bf” Picture Package Filter 23.5 - from the file “ChannelPort.8bf” Pinch 23.5 - from the file “Standard MultiPlugin.8bf” Pixar 23.5 - from the file “Pixar.8bi” Plaster 23.5 - from the file “Filter Gallery.8bf” Plastic Wrap 23.5 - from the file “Filter Gallery.8bf” Pointillize 23.5 - from the file “Standard MultiPlugin.8bf” Polar Coordinates 23.5 - from the file “Standard MultiPlugin.8bf” Portable Bit Map 23.5 - from the file “PBM.8bi” Poster Edges 23.5 - from the file “Filter Gallery.8bf” PRC 23.5 - from the file “U3D.8bi” Radial Blur 23.5 - from the file “Standard MultiPlugin.8bf” Radiance 23.5 - from the file “Radiance.8bi” Range 23.5 - from the file “statistics.8ba” Render Color Lookup Grid 23.5 - from the file “Export3DLUT.8be” Reticulation 23.5 - from the file “Filter Gallery.8bf” Ripple 23.5 - from the file “Standard MultiPlugin.8bf” Rough Pastels 23.5 - from the file “Filter Gallery.8bf” Save for Web 23.5 - from the file “Save for Web.8be” ScriptingSupport 23.5 - from the file “ScriptingSupport.8li” Shear 23.5 - from the file “Standard MultiPlugin.8bf” Skewness 23.5 - from the file “statistics.8ba” Smart Blur 23.5 - from the file “Standard MultiPlugin.8bf” Smudge Stick 23.5 - from the file “Filter Gallery.8bf” Solarize 23.5 - from the file “Solarize.8bf” SP Substance Suite NO VERSION - from the file “MaterialSuite.8li” Spatter 23.5 - from the file “Filter Gallery.8bf” Spherize 23.5 - from the file “Standard MultiPlugin.8bf” Sponge 23.5 - from the file “Filter Gallery.8bf” Sprayed Strokes 23.5 - from the file “Filter Gallery.8bf” Stained Glass 23.5 - from the file “Filter Gallery.8bf” Stamp 23.5 - from the file “Filter Gallery.8bf” Standard Deviation 23.5 - from the file “statistics.8ba” Substance Filter NO VERSION - from the file “MaterialFilter.8bf” Sumi-e 23.5 - from the file “Filter Gallery.8bf” Summation 23.5 - from the file “statistics.8ba” Targa 23.5 - from the file “Standard MultiPlugin.8bf” Texturizer 23.5 - from the file “Filter Gallery.8bf” Tiles 23.5 - from the file “Standard MultiPlugin.8bf” Torn Edges 23.5 - from the file “Filter Gallery.8bf” Twirl 23.5 - from the file “Standard MultiPlugin.8bf” U3D 23.5 - from the file “U3D.8bi” Underpainting 23.5 - from the file “Filter Gallery.8bf” Vanishing Point 23.5 - from the file “VanishingPoint.8bf” Variance 23.5 - from the file “statistics.8ba” Water Paper 23.5 - from the file “Filter Gallery.8bf” Watercolor 23.5 - from the file “Filter Gallery.8bf” Wave 23.5 - from the file “Standard MultiPlugin.8bf” WIA Support 23.5 - from the file “WIASupport.8li” Wind 23.5 - from the file “Standard MultiPlugin.8bf” Wireless Bitmap 23.5 - from the file “WBMP.8bi” ZigZag 23.5 - from the file “Standard MultiPlugin.8bf” Optional and third party plugins: Filter Forge 11 11.005.63141.22082 Release, May 23, 2022 14:44 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2022\Plug-ins\Filter Forge 11 Universal plugin\Filter Forge 11\Plugin\x64\Filter Forge 11 x64.8bf” Duplicate and Disabled plugins: NONE Plugins that failed to load: Filter Forge 11 NO VERSION - - from the file “C:\Program Files\Adobe\Adobe Photoshop 2022\Plug-ins\Filter Forge 11 Universal plugin\Filter Forge 11\Plugin\Filter Forge 11.8bf” Unified Extensibility Platform - Extensions: Home Screen (Loaded) 6.0.0.31 - from the file "C:\Program Files\Common Files\Adobe/UXP/Extensions\com.adobe.ccx.start-6.0.0\" CDO: 1.127.1 CmdN: 1.14.4 CDP: 1.151.0 Projects: 1.4.8 Loaded at: 46 ms - launch time impact: 38 ms Content Credentials (Loaded) 0.31.6.0 - from the file "Required Folder" Loaded at: 102945 ms - launch time impact: 0 ms ccx-timeline (Prepared) 3.0.3.0 - from the file "Required Folder" CCX Commenting UXP Webview (Loaded) 23.6.0.0 - from the file "Required Folder" Loaded at: 102945 ms - launch time impact: 0 ms CCX Sharesheet UXP (Prepared) 23.12.0.0 - from the file "Required Folder" Photoshop Cloud Value Dialog (Loaded) 1.0.1.0 - from the file "Required Folder" Loaded at: 48 ms - launch time impact: 0 ms Share Panel (Loaded) 1.0.3.0 - from the file "Required Folder" Loaded at: 48 ms - launch time impact: 0 ms Free Stock Search 2 (Prepared) 2.1.0.0 - from the file "Plugin Market Place" CC Libraries Panel (Prepared) 3.21.13.0 - from the file "C:\Program Files\Common Files\Adobe/CEP/Extensions\CC_LIBRARIES_PANEL_EXTENSION_3_21_13\" CAPTURE: 2.0.41 STOCK: 4.0.2 Photoshop UXP Export-As (Prepared) 5.8.13.0 - from the file "Required Folder" Photoshop In App Messaging (Loaded) 2.7.5.0 - from the file "Required Folder" Loaded at: 102945 ms - launch time impact: 0 ms Photoshop Selection Feedback (Prepared) 0.5.0.0 - from the file "Required Folder" Plugins Panel (Prepared) 1.4.3.0 - from the file "Required Folder" IC popup message (Loaded) 1.0.0.0 Loaded at: 4899 ms - launch time impact: 0 ms Multilayer Protection (Loaded) 1.0.0.0 Loaded at: 4899 ms - launch time impact: 0 ms Discover Panel (Loaded) 2.9.0.29 - from the file "Required Folder" Loaded at: 102946 ms - launch time impact: 17 ms Neural Filters (Registered) 1.13.3.0 - from the file "Required Folder" Extensions: Libraries 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_21_13\index.html” com.adobe.stock.panel.licensing-embedded 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_21_13\extensions\stock-panel-licensing\index.html” com.adobe.capture.extension 2.0.41 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_21_13\extensions\capture\capture.html” Export As 4.8.15 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2022\Required\CEP\extensions\com.adobe.photoshop.crema\index.html” Export As 4.8.15 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2022\Required\CEP\extensions\com.adobe.photoshop.crema\index.html” com.adobe.cclibraries.manager 1.0.0 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_21_13\manager.html” Installed TWAIN devices: NONE |
| Posted: October 21, 2022 11:01 am | ||||||
Allele Graphics
Posts: 8 |
"In another Finder window, open Library > Application Support > Adobe > Plug-Ins > CC" I am totally dumbfounded because I can't find "Library > Application Support > Adobe > Plug-Ins > CC" anywhere on my computer... I have "Programs > Adobe > Plug-ins > Filters" open... and I did this... "Alt+Command+drag and drop the file from the first window to the second one" - when I open Photoshop it has an error code "One or more plug-ins are currently not available on your system. For details, see Help > System Info." when I hit ok, and start a new file... then when I go to Plugins drop down it is NOT listed, but when I go to Filters drop down it shows up there... when I click on it has an error code: "Could not complete the Filter Forge 11 command because of a problem with the filter module interface." So SORRY to be such a pest.... smile:| |
| Posted: October 22, 2022 10:16 am | ||||||
Posts: 3507 |
One of the first steps was to check the "Library/Application Support/Adobe/Plug-Ins/CC/" folder and and remove all Filter Forge 11-related files fr om there. Did you skip this step before getting to "In another Finder window, open... " ? Please try again from the beginning. If there is no "Library/Application Support/Adobe/Plug-Ins/CC/" folder on your Mac, you need to create it.
No. Copying files to a random location will make things worse. Please remove the alias from the folder wh ere it doesn't belong. |
| Posted: October 24, 2022 6:35 am | ||||||
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
20 unregistered users.
