Torley
Posts: 303 |
Ooooh, so I was looking at the current list of Filter Forge categories, both within FF and under the "All Filters by Category" list @ http://www.filterforge.com/filters/ , and had some questions:
* How was the current categorization decided upon? For example, "Stone" might fit under under "Organic", or to some, "Wood" and "Metal" could have their own category, or those could be under "Building" too. (I know how subjective this is, just thinking out loud!) * Why are there two "Frames" categories? There's one each in "Textures" and "Effects", and there appears to be a lot of overlap. That being said, I like how simple the current categorization is, and use the Favorites to tag choice picks, but was wondering if anyone else had ideas for clarification and/or expansion. Thanx! I'm enjoying using Filter Forge to create http://torley.com/textures |
| Posted: March 11, 2007 6:42 am | ||||
As the library grows, the current categorization will hopefully be replaced by something more efficient. Personally, I think the categories should be abandoned in favor of a more flexible system using tags with levels of generalization or 'depth'.
For example, my 'Lounge Lizards' filter (currently in the 'Misc' category) could have several tags to categorize it, like 'Building > Interior > Furniture > Chair/Sofa', with each level going into more 'depth'. It could also be tagged as 'Building > Interior > Wall > Fabric' or 'Nature > Organics > Skin > Leather', depending on which preset your looking at and what usage you have in mind. When I chose the category for this filter, I was torn between 'Building' (because it's furniture/interior themed), 'Techno' and 'Organics'. It ended up in 'Misc' because it was basically a bit of everything of the above. Had I been able to choose tags instead of fixed categories, the whole thing probably would have been categorized much better. We could have clusters of super-tags, tags and sub-tags designed to allow for broad and fine categorization. 'building' for example would be a super-tag that includes derivative sub-tags like exterior, interior, which in turn include wall, floor, etc. So, by choosing to look for all 'interior' tagged filters, the user would get filters for walls, floors, furniture, decorative items, carpets, wallpaper patterns, plants, cushion designs, etc., which - under the current system - would be scattered across several categories. He could then further refine his search by choosing a tag from a 'deeper' level or by excluding certain sub-tags. Say he doesn't want his 'interior' tag search ruined by those millions of abstract wallpaper patterns and just excluded filters with those tags. There are lots of possibilities in there... --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: March 11, 2007 4:10 pm | ||||
Torley
Posts: 303 |
^ Great thoughts, Crapadilla. For the record, I like tags a *lot*. And tag clouds too. It's just so easy and effective to stick a bunch of words to help find what you're looking for — community-based tagging options would help even more, when other people expect to find your work through some keywords but can't. It's like how I have my Flickr photos set so anyone can add tags and help me find my own stuff if there are keywords I didn't think of initially.
| Posted: March 11, 2007 9:15 pm | ||||
I agree with everything that has been said.
The only strict categories (mutually exclusive) should be the textures (no ext. image) and effects (with ext. image). *As a side note I'm not sure those are necessarily the best names. You can certainly make a texture filter with images which is confusing. |
| Posted: March 11, 2007 10:43 pm | ||||
Administrator |
Yes, tags would work well here. I hate strict taxonomies myself (and I'm not fond of designing them either) -- we just didn't have time to implement a proper tagging-based system. |
| Posted: March 12, 2007 5:37 am | ||||
it is for exactly that reason that i'm currently argueing for a simple 'downloaded filters' category and that's it. nothing more. but, the user then has to have access to his own folder making capability so that he can sort out where he wants to put all of his filters he just downloaded and the ones he/she makes. if you want to also add tags and search to the 'downloaded filters', that's fine, but to me, i'd like to sort and pick and delete and such on my own terms. the user has already added keywords to his filter. so a search on keywords and author names shld be sufficient with the system i want. just give me the ability to make and organize my own filter file tree and i'm happy ok, so the counter arguement to this has to be, most folks arent going to do that. they just want to be able to find a filter quickly and use it and forget it or add it to 'my favorites'. and that's fine. keep the current categories and just add the ability to make and handle a file tree in my filters or my favorites or both and again, i'm happy If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: March 12, 2007 3:46 pm | ||||
+7 new in 7 days!
19 unregistered users.
